[Swift-devel] process hogging memory on ranger login
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Nov 25 13:24:52 CST 2009
On Wed, 2009-11-25 at 11:50 -0600, skenny at uchicago.edu wrote:
> /ci/projects/cnari/logs/skenny/importDTI-20091124-1655-agj0mze1.log
> >> let me know if you need the coaster log as well.
> >That may occur at times, such as when the service runs out of
> memory. So
> >yes, I do need the coaster log.
> >Regardless of the exact reason, I think that there needs to
> be extra
> >logic in there to ensure liveness. In other words a lost
> state should
> >not be interpreted as "still in last state" but "failure".
> ok, just added the coasters.log to that same dir:
> /ci/projects/cnari/logs/skenny/coasters.log
Looks like the jobs go way over their walltime and that causes badness.
I'll investigate.
In the mean time, you could try to figure out why the jobs take much
longer than expected or adjust the expectation (walltime) accordingly.
