[Swift-devel] process hogging memory on ranger login
Mihael Hategan hategan at mcs.anl.gov
Tue Nov 24 16:14:37 CST 2009
On Mon, 2009-11-23 at 19:01 -0600, skenny at uchicago.edu wrote:
> so, i was trying to re-run this workflow with the latest swift
> (swift-r3191 cog-r2620) to try and replicate the error.
> however, a new error has surfaced...the environment, as
> specified in my tc.data file, is no-longer being set by swift
> on the remote end. is it possible this is due to recent
> changes in swift? i am running the same workflow, same tc &
> sites files with the newer swift and am getting errors (from
> the app) due to my LD_LIBRARY_PATH not being set. if i switch
> back to swift-r3116 cog-r2482, the error goes away.
This was a bug introduced earlier during some changes to how the profile
stuff was handled. Should be fixed in swift r3192.
