[Swift-devel] [Bug 221] New: -config option doesnt seem to use etc/swift.properties as a base
bugzilla-daemon at mcs.anl.gov
Sat Nov 14 16:30:11 CST 2009
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=221
Summary: -config option doesnt seem to use etc/swift.properties
as a base
Product: Swift
Version: unspecified
Platform: All
OS/Version: All
Status: NEW
Severity: minor
Priority: P3
Component: SwiftScript language
AssignedTo: hategan at mcs.anl.gov
ReportedBy: wilde at mcs.anl.gov
When the -config option on the swift command line is given a file with just a
few properties to override, then it sees like etc/swift.properties is not read
in first as a base (as the user guides indicates it should be).
Its not clear if this is intentional (and a user guide error) or inadvertent.
This behavior is seen in this example:
com$ swift psim.itfixex1.swift
Swift svn swift-r3187 cog-r2579
RunID: 20091114-1623-10i1k2g3
com$ swift -config set.properties psim.itfixex1.swift
Execution failed:
File not found ${vds.home}/etc/sites.xml
com$ cat set.properties
execution.retries=2
sitedir.keep=false
com$
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
You are watching the reporter.
