[Swift-devel] Unexpected messages from coasters on BG/P
Michael Wilde wilde at mcs.anl.gov
Wed Nov 11 10:38:31 CST 2009
Mihael, can you tell me what the messages below mean?
- the block ended prematurely message
- the long java tracebacks (seems like one per each of 256 jobs?
Will send more logs later if needed.
Mike
Progress:  uninitialized:3
Progress:  Stage in:240  Submitting:16
Progress:  Stage in:169  Submitting:87
Progress:  Stage in:61  Submitting:195
Progress:  Submitted:256
Worker task failed: 1111-271019-000000Block task ended prematurely
Progress:  Submitted:255  Active:1
Failed to transfer wrapper log from
raxmlex1-20091111-1027-26gklim9/info/z on surveyor
Progress:  Active:256
Unknown handler: CANCELJOB. Available handlers: {CHMOD=class
org.globus.cog.abstraction.impl.file.coaster.handlers.ChmodHandler,
ISDIR=class
org.globus.cog.abstraction.impl.file.coaster.handlers.IsDirectoryHandler,
LIST=class
org.globus.cog.abstraction.impl.file.coaster.handlers.ListHandler,
SUBMITJOB=class
org.globus.cog.abstraction.coaster.service.SubmitJobHandler, MKDIR=class
org.globus.cog.abstraction.impl.file.coaster.handlers.MkdirHandler,
PUT=class
org.globus.cog.abstraction.impl.file.coaster.handlers.PutFileHandler,
DEL=class
org.globus.cog.abstraction.impl.file.coaster.handlers.DeleteHandler,
CONFIGSERVICE=class
org.globus.cog.abstraction.coaster.service.ServiceConfigurationHandler,
FILEINFO=class
org.globus.cog.abstraction.impl.file.coaster.handlers.FileInfoHandler,
SHUTDOWNSERVICE=class
org.globus.cog.abstraction.coaster.service.ServiceShutdownHandler,
SHUTDOWN=class
org.globus.cog.karajan.workflow.service.handlers.ShutdownHandler,
EXISTS=class
org.globus.cog.abstraction.impl.file.coaster.handlers.ExistsHandler,
CHANNELCONFIG=class
org.globus.cog.karajan.workflow.service.handlers.ChannelConfigurationHandler,
RMDIR=class
org.globus.cog.abstraction.impl.file.coaster.handlers.RmdirHandler,
VERSION=class
org.globus.cog.karajan.workflow.service.handlers.VersionHandler,
RENAME=class
org.globus.cog.abstraction.impl.file.coaster.handlers.RenameHandler,
WORKERSHELLCMD=class
org.globus.cog.abstraction.coaster.service.WorkerShellHandler, GET=class
org.globus.cog.abstraction.impl.file.coaster.handlers.GetFileHandler}
ISDIR=class
LIST=class
SUBMITJOB=class
PUT=class
DEL=class
CONFIGSERVICE=class org.globus.cog.abstraction.
