[Swift-devel] exception caught while writing to log file
Mihael Hategan
hategan at mcs.anl.gov
Mon Nov 9 16:45:49 CST 2009
On Mon, 2009-11-09 at 13:10 -0600, Mihael Hategan wrote:
> On Mon, 2009-11-09 at 13:05 -0600, Michael Wilde wrote:
> > I've not seen it. The log below is 7.8GB in size, but it looks like its
> > failing on a write to the restart log.
> Justin reported the same on a small workflow.
> It seems to be a case of writing to the log after it has been closed due
> to some improper synchronization issue.
Should be fixed in svn.
In any event, it isn't generally consequential. It happens as a
consequence of the run failing, and does not by itself cause the
failure.
