[Swift-devel] Re: [Swift-user] swift syntax problem (please ignore the previous one )
    Ben Clifford
    benc at hawaga.org.uk
    Fri May 29 18:41:58 CDT 2009
You can use some code like the below. This uses the simple mapper to
generate a new filename for otherfile, based on substituting "foo" for
"hello".
type messagefile;
app (messagefile t) greeting() {
    echo "Hello, world!" stdout=@filename(t);
messagefile outfile <"/tmp/hello.txt">;
messagefile otherfile
<single_file_mapper;file="/"+ at regexp(@filename(outfile),"hello","foo")>;
otherfile = greeting();
