[Swift-devel] Issues when running swift on fuse
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May 29 16:30:00 CDT 2009
On Fri, 2009-05-29 at 13:09 -0500, yizhu wrote:
> Mihael Hategan wrote:
> > That's strange. You are getting multiple errors, both for the log file
> > and the restart log. But the restart log should be small (and for
> > first.swift, so should be the execution log). So I suspect the error
> > message is misleading.
> Yes, i think you are right, I noticed that swift is trying to generate
> log file with size more that 18446744073GB, which cause the file two
> large problem.
Swift doesn't generate empty logs of a pre-set size. And the size you
mention is insanely large.
So I think this is a bug in the s3 driver. I'm not sure why swift
triggers it.
