[Swift-devel] block allocation
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon May 25 07:57:25 CDT 2009
If you want a reservation, you write an email about the requirements and
deadlines, which then gets replied back with a schedule, times, number
of processors, time allocation, and a queue name. It is then up to the
respective individual to submit jobs to the right queue, which will
place the jobs in a hold state if its prior to the reservation start
time, and it will release them only when the reservation time is
reached. Job walltime needs to be set within the bounds of the
reservation (e.g. if the reservation is for 60 minutes, a job wall time
cannot be 70 minutes, if half way through a reservation that has 30
minutes left, one cannot submit a job for 40 minutes, even if a 40
minute job would have been accepted earlier in the reservation).
Now, many people using Falkon and block allocation on the BG/P run
without any reservations. They simply submit their jobs to the
appropriate queue (not specific to the user, but specific to job
requirements), and once the jobs go through, the blocks get
instantiated, and the user uses the block allocation until it runs out
and it de-allocates itself. At that point, if the workload was not
complete, the user would manually invoke the block allocation again, and
let the workload continue where it left off earlier. And the process
would continue as long as there was work.
Ioan
Ben Clifford wrote:
> On Sun, 24 May 2009, Mihael Hategan wrote:
>> PS: On the topic of static allocations, in people's experience, how does
>> one specify reservations on various resources?
> I've only done that by sending email to help at teragrid.org, which is a
> relatively high latency and expensive operation.
Ioan Raicu, Ph.D.
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090525/1c40ef0f/attachment.html>
