[Swift-devel] Re: could not start coaster on Ranger
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed May 20 11:58:00 CDT 2009
got it, I used the wrong project name.
zhao
Zhao Zhang wrote:
> Hi,
> I am trying to run a sanity test with coaster on ranger.
> Here is my sites.xml definition:
> [zzhang at communicado sites]$ cat coaster_test/tgranger-sge-gram2.xml
> <config>
>  <pool handle="tgtacc" >
>    <gridftp  url="gsiftp://gridftp.ranger.tacc.teragrid.org" />
>    <execution  provider="coaster"
> url="gatekeeper.ranger.tacc.teragrid.org" jobManager="gt2:gt2:SGE"/>
>    <!-- <profile namespace="globus"
> key="project">TG-DBS080005N</profile> -->
>    <profile namespace="globus" key="project">TG-MCB080099N</profile>
>    <workdirectory >/work/00946/zzhang/work</workdirectory>
>    <profile namespace="env"
> key="SWIFT_JOBDIR_PATH">/tmp/zzhang/jobdir</profile>
>    <profile namespace="globus" key="coastersPerNode">16</profile>
>    <profile namespace="globus" key="queue">development</profile>
> key="coasterWorkerMaxwalltime">00:40:00</profile>
>    <profile namespace="globus" key="maxwalltime">31</profile>
>    <profile namespace="karajan" key="initialScore">50</profile>
>    <profile namespace="karajan" key="jobThrottle">10</profile>
>  </pool>
> </config>
> Then it failed with the following errors. Is there any configuration
> error I put there in the sites.xml? or any
> other information you need, please let me know.
> zhao
> [zzhang at communicado sites]$ ./run-site
> testing site configuration: coaster_test/tgranger-sge-gram2.xml
> Removing files from previous runs
> Running test 061-cattwo at Wed May 20 11:47:23 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090520-1147-yov15zb6
> Progress:  uninitialized:1
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Progress:  Active:1
> Failed to transfer wrapper log from
> 061-cattwo-20090520-1147-yov15zb6/info/k on tgtacc
> Progress:  Active:1
> 061-cattwo-20090520-1147-yov15zb6/info/m on tgtacc
> Progress:  Active:1
> 061-cattwo-20090520-1147-yov15zb6/info/o on tgtacc
> Progress:  Failed:1
> Execution failed:
>        Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: tgtacc
> Directory: 061-cattwo-20090520-1147-yov15zb6/jobs/o/cat-oa9l83bj
> stderr.txt:
> stdout.txt:
> Caused by:
>        Failed to start worker:
> null
> null
> org.globus.gram.GramException: The job manager detected an invalid
> script response
>        at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>        at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>        at
> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>        at java.lang.Thread.run(Thread.java:619)
> Cleaning up...
> Shutting down service at https://129.114.50.163:60748
> Got channel MetaChannel: 4609608 -> GSSSChannel-null(1)
> - Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
