[Swift-devel] Re: coaster features
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon May 18 14:08:54 CDT 2009
Hi, All
Mihael Hategan wrote:
> On Thu, 2009-05-14 at 11:36 -0500, Zhao Zhang wrote:
>>> I'm not sure how you know it's working if you don't know what it's
>>> supposed to do.
>> Yes, there is a test case in Ben's test suite using the
>> coasterInternalIP variable. Things I know is that the test returned
>> successful.
> Did you try to remove that parameter and see if there is a difference?
>>> Without this, workers use the external IP (the one the service is
>>> started with) to contact the service. With it, one can force the workers
>>> to contact a specific IP after starting. This is needed if the worker
>>> nodes don't generally have access to the outside of the cluster.
>>> This has nothing to do with notification or status files. If this
>>> setting is required (due to the network configuration of the cluster)
>>> and it is not specified, the coasters won't work at all.
>>>> 4) coasterDataProvider
>>>>     This is working now.
>>> I don't know what that is.
>> This is the "<filesystem provider="coaster" url="gt2://grid.myhost.org"
>> />" from http://www.ci.uchicago.edu/swift/guides/userguide/coasters.php.
> Right. The coaster fs provider. Glen found some data corruption with it
> when transferring files larger than a few KB. So it's only somewhat
> working.
Has this feature been fixed? I found it again in my data movement test
on OSG site.
zhao
