[Swift-devel] Globus Job Manager Scaling (fwd) with Swift
    Ben Clifford
    benc at hawaga.org.uk
    Fri May 15 12:25:10 CDT 2009
I've heard that there is some work within OSG for deploying GRAM5 test
installations. I'm interested in pointing a Swift client at this and
seeing how it compares to other mechanisms we have for submitting to OSG.
> From: Stuart Martin <smartin at mcs.anl.gov>
> Date: May 12, 2009 4:40:27 PM CDT
> To: Chander Sehgal <cssehgal at fnal.gov>
> Cc: Stuart Martin <smartin at mcs.anl.gov>, 'Steve Tuecke' <tuecke at uchicago.edu>,
> 'Dan Fraser' <fraser at anl.gov>, 'Alain Roy' <roy at cs.wisc.edu>, 'Ruth'
> <ruth at fnal.gov>
> Subject: Re: Globus Job Manager Scaling
> Sounds good.  Dan, lemme know what your plan is.
> -Stu
> On May 12, 2009, at May 12, 4:24 PM, Chander Sehgal wrote:
> > Stu,
> > Thanks for the update.  I am going to pass this baton to Dan Fraser in his
> > OSG Production Coordinator role.  He is trying to sort out how to move LIGO
> > E at H forward and this is part of that...
> > Chander
> > -----Original Message-----
> > From: Stuart Martin [mailto:smartin at mcs.anl.gov]
> > Sent: Tuesday, May 12, 2009 9:18 AM
> > To: Chander Sehgal
> > Cc: Stuart Martin; Steve Tuecke; Dan Fraser; Alain Roy
> > Hi Chander,
> > I just sent this to gram-dev as a general announcement:
> > http://lists.globus.org/pipermail/gram-dev/2009-May/001427.html
> > Yes - GRAM5 is designed to solve the scalability issues that non-
> > condor-g clients have using GRAM2.  So I'd recommend this Alpha being
> > setup on a Nebraska test host and have E at Home try it out.  It has
> > looked good in our testing, we'd love to get some real world
> > deployments and testing to see how it holds up.
> > Do you want to convene a telecon with the various people that will be
> > involved with this?
> > Lemme know how I can help.
> > -Stu
