[Swift-devel] Tool for TeraGrid site info
    Michael Wilde
    wilde at mcs.anl.gov
    Wed May 13 13:10:05 CDT 2009
Glen, your code would in this case be used as a base, for as long as its
useful.
Like any initial cut of a tool, many hands may contribute over time, and
the code may get partially or totally re-written.
Signing the contributor's agreement ensures that the code (and code
derived form it) remains available for open usage.
So assuming that you're OK with that, you should do so.
- Mike
On 5/13/09 1:03 PM, Glen Hocky wrote:
> Though I would happy to be a contributor, I would say my code at best
> should be a guideline.
> Oh, and I have a commandline help
> On May 13, 2009, at 12:56 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
>> On Wed, 13 May 2009, skenny at uchicago.edu wrote:
>>> we are looking at using glen's code as a starting point for a
>>> tool that could be included in swift/committed to swift's svn.
>>> there will need to be quite a bit of testing first as i'm
>>> unsure about committing someone else's code 'as is'...
>> I think a bunch of testing will show whether code is useful or not.
>> But it
>> needs additional stuff like documentation. Mats' work on the OSG sites
>> file generator went in quite easily - it has some basic documentation
>> (the
>> command line help) and it worked in a bunch of informal tests. Ideally
>> the
>> test suite and the userguide would be appropraitely amended too...
>>> my other question regarding this is that there is apparently
>>> some *paperwork* involved in this process which would require
>>> me (and glen?) to sign some sort of globus licensing agreement
>> mmm paperwork. If you're working on glen's code, then at least you, glen,
>> glen's employer and your employer need to sign globus contributor
>> licenses
>> or have existing licenses appropriately amended to cover you/him.
>> I think maybe you don't already have a license signed - I don't remember
>> you doing one. In which case look at
>> http://dev.globus.org/wiki/Guidelines#License_and_Contributor_Agreements
>> for the individual license agreement and give a copy to Gigi.
>> Glen needs to do the same, and have his employer(s) give a license - I
>> don't know in his case who employs him.
>> (the above reflects my understanding of the dev.globus guideliens and is
>> not to be construed as legal advice under US, UK or South African law)
