[Swift-devel] Swift-issues (PBS+NFS Cluster)
Ian Foster
foster at anl.gov
Tue May 12 12:31:51 CDT 2009
Tim:
Yes, running experiments is going to be an important early task.
Ian.
On May 12, 2009, at 11:53 AM, Tim Freeman wrote:
> On Tue, 12 May 2009 11:42:00 -0500
> yizhu <yizhu at cs.uchicago.edu> wrote:
>> That's great. It makes file management between EC2 and S3 much
>> easier, I
>> will definitely check it out.
> Note that every I/O op to S3 will be significantly slower than EBS
> (and
> probably also slower than the local scratch disk). Add in FUSE
> (userspace) and
> that only compounds the problem. So if you use this option I would
> suggest
> taking measurements to make sure it is acceptable for the task at
> hand.
> Tim
>> Michael Wilde wrote:
>>> Maybe relevant - there's a FUSE filesystem to mount an S3 bucket
>>> as a
>>> filesystem:
>>> http://code.google.com/p/s3fs/wiki/FuseOverAmazon
>>> - Mike
>>> On 5/12/09 11:19 AM, Ioan Raicu wrote:
>>>> Hi,
>>>> yizhu wrote:
>>>>> Hi,
>>>>> I've now got the swift system running on Amazon EC2 with swift
>>>>> installed on head-node of the cluster. I will soon let it the user
>>>>> submit the job from its own machine after i solve the
>>>>> authentication
>>>>> issues of Globus.
>>>>> I think my next step is to write a sample swift code to check if
>>>>> we
>>>>> can let swift grab input files from S3, execute it, and then write
>>>>> the output files back to S3.
>>>>> Since each Amazon virtual node only has limited storage
>>>>> space( Small
>>>>> instance for 1.7GB, Large Instance for 7.5GB),
>>>> Are you sure? That sounds like like the amount of RAM each instance
>>>> gets. The last time I used EC2 (more than a year ago), each
>>>> instance
>>>> had a disk of 100GB+ each, which could be treated as a scratch disk
>>>> that would be lost when the instance was powered down.
>>>>> we may need to use EBS(Elastic Block Store) to storage temp files
>>>>> created by swift. The EBS behaved like a hard disk volume and
>>>>> can be
>>>>> mounted by any virtual nodes. But here arise a problem, since a
>>>>> volume can only be attached to one instance at a time[1], so the
>>>>> files store in EBS mounted by one node won't be shared by any
>>>>> other
>>>>> nodes;
>>>> The EBS sounds like the same thing as the local disk, except that
>>>> it
>>>> is persisted in S3, and can be recovered when the instance is
>>>> started
>>>> again later.
>>>> You can use these local disks, or EBS disks, to create a
>>>> shared/parallel file system, or manage them yourself.
>>>>> we lost the file sharing ability which I think is a fundamental
>>>>> requirement for swift.
>>>> The last time I worked with the Workspace Service (now part of
>>>> Nimbus), we were able to use NFS to create a shared file system
>>>> across
>>>> our virtual cluster. This allowed us to run Swift without
>>>> modifications on our virtual cluster. Some of the more recent
>>>> work on
>>>> Swift might have eased up some of the requirements for a shared
>>>> file
>>>> system, so you might be able to run Swift without a shared file
>>>> system, if you configure Swift just right. Mike, is this true, or
>>>> we
>>>> aren't quite there yet?
>>>> Ioan
>>>>> -Yi
>>>>>> On 5/7/09 12:54 PM, Tim Freeman wrote:
>>>>>>> On Thu, 07 May 2009 11:39:40 -0500
>>>>>>>>> Very good!
>>>>>>>>> Now, what kind of tests can you do next?
>>>>>>>> Next, I will try to let swift running on Amazon EC2.
>>>>>>>>> Can you exercise the cluster with an interesting workflow?
>>>>>>>> Yes, Is there any complex sample/tools i can use (rahter than
>>>>>>>> first.swift) to test swift performance? Is there any benchmark
>>>>>>>> available i can compare with?
>>>>>>>>> How large of a cluster can you assemble in a Nimbus
>>>>>>>>> workspace ?
>>>>>>>> Since the vm-image i use to test 'swift' is based on NFS shared
>>>>>>>> file system, the performance may not be satisfiable if the we
>>>>>>>> have
>>>>>>>> a large scale of cluster. After I got the swift running on
>>>>>>>> Amazon
>>>>>>>> EC2, I will try to make a dedicate vm-image by using GPFS or
>>>>>>>> any
>>>>>>>> other shared file system you recommended.
>>>>>>>>> Can you aggregate VM's from a few different physical clusters
>>>>>>>>> into one Nimbus workspace?
>>>>>>>> I don't think so. Tim may make commit on it.
>>>>>>> There is some work going on right now making auto-configuration
>>>>>>> easier to do
>>>>>>> over multiple clusters (that is possible now, it's just very
>>>>>>> 'manual' and
>>>>>>> non-ideal unlike with one physical cluster). You wouldn't
>>>>>>> really
>>>>>>> want to do NFS
>>>>>>> across a WAN, though.
>>>>>> Indeed. Now that I think this through more clearly, one
>>>>>> workspace ==
>>>>>> one cluster == one Swift "site", so we could aggregate the
>>>>>> resources
>>>>>> of multiple workspaces through Swift to execute a multi-site
>>>>>> workflow.
>>>>>> - Mike
>>>>>>>>> What's the largest cluster you can assemble with Nimbus?
>>>>>>>> I am not quite sure,I will do some test onto it soon. since
>>>>>>>> it is
>>>>>>>> a EC2-like cloud, it should easily be configured as a cluster
>>>>>>>> with
>>>>>>>> hundreds of nodes. Tim may make commit on it.
>>>>>>> I've heard of EC2 deployments in the 1000s at once, it's up to
>>>>>>> your
>>>>>>> EC2 account
>>>>>>> limitations (they seem pretty efficient with making your quota
>>>>>>> ever-higher).
>>>>>>> Nimbus installation at Teraport maxes out at 16, there are other
>>>>>>> 'science
>>>>>>> clouds' but I don't know their node numbers. EC2 is the place
>>>>>>> where you will
>>>>>>> be able to really test scaling something.
>>>>>>> Tim
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090512/864f351b/attachment.html>
