[Swift-devel] Swift-issues (PBS+NFS Cluster)
Michael Wilde
wilde at mcs.anl.gov
Tue May 12 12:10:36 CDT 2009
On 5/12/09 12:04 PM, Michael Wilde wrote:
> Indeed.
> I should note that the intent in Swift is to reduce or eliminate
> accesses to shared filesystems, so EBS and S3 would become similar.
> The basic model of running a job would be: pull in the data you need,
> operate on it on local disk, push it back. Cache locally where possible.
> Only read direct from shared storage when the data is too big.
> This is pretty much what happens now, except that the "pull" and "push"
> are staged via a site shared filesystem.
(and that it doesnt do any size discrimination, I should add)
> - Mike
> On 5/12/09 11:53 AM, Tim Freeman wrote:
>> On Tue, 12 May 2009 11:42:00 -0500
>> yizhu <yizhu at cs.uchicago.edu> wrote:
>>> That's great. It makes file management between EC2 and S3 much
>>> easier, I will definitely check it out.
>> Note that every I/O op to S3 will be significantly slower than EBS (and
>> probably also slower than the local scratch disk). Add in FUSE
>> (userspace) and
>> that only compounds the problem. So if you use this option I would
>> suggest
>> taking measurements to make sure it is acceptable for the task at hand.
>> Tim
>>>> Maybe relevant - there's a FUSE filesystem to mount an S3 bucket as
>>>> a filesystem:
>>>> http://code.google.com/p/s3fs/wiki/FuseOverAmazon
>>>> - Mike
>>>> On 5/12/09 11:19 AM, Ioan Raicu wrote:
>>>>> Hi,
>>>>> yizhu wrote:
>>>>>> Hi,
>>>>>> I've now got the swift system running on Amazon EC2 with swift
>>>>>> installed on head-node of the cluster. I will soon let it the user
>>>>>> submit the job from its own machine after i solve the
>>>>>> authentication issues of Globus.
>>>>>> I think my next step is to write a sample swift code to check if
>>>>>> we can let swift grab input files from S3, execute it, and then
>>>>>> write the output files back to S3.
>>>>>> Since each Amazon virtual node only has limited storage space(
>>>>>> Small instance for 1.7GB, Large Instance for 7.5GB),
>>>>> Are you sure? That sounds like like the amount of RAM each instance
>>>>> gets. The last time I used EC2 (more than a year ago), each
>>>>> instance had a disk of 100GB+ each, which could be treated as a
>>>>> scratch disk that would be lost when the instance was powered down.
>>>>>> we may need to use EBS(Elastic Block Store) to storage temp files
>>>>>> created by swift. The EBS behaved like a hard disk volume and can
>>>>>> be mounted by any virtual nodes. But here arise a problem, since a
>>>>>> volume can only be attached to one instance at a time[1], so the
>>>>>> files store in EBS mounted by one node won't be shared by any
>>>>>> other nodes;
>>>>> The EBS sounds like the same thing as the local disk, except that
>>>>> it is persisted in S3, and can be recovered when the instance is
>>>>> started again later.
>>>>> You can use these local disks, or EBS disks, to create a
>>>>> shared/parallel file system, or manage them yourself.
>>>>>> we lost the file sharing ability which I think is a fundamental
>>>>>> requirement for swift.
>>>>> The last time I worked with the Workspace Service (now part of
>>>>> Nimbus), we were able to use NFS to create a shared file system
>>>>> across our virtual cluster. This allowed us to run Swift without
>>>>> modifications on our virtual cluster. Some of the more recent work
>>>>> on Swift might have eased up some of the requirements for a shared
>>>>> file system, so you might be able to run Swift without a shared
>>>>> file system, if you configure Swift just right. Mike, is this true,
>>>>> or we aren't quite there yet?
>>>>> Ioan
>>>>>> -Yi
>>>>>>> On 5/7/09 12:54 PM, Tim Freeman wrote:
>>>>>>>> On Thu, 07 May 2009 11:39:40 -0500
>>>>>>>>>> Very good!
>>>>>>>>>> Now, what kind of tests can you do next?
>>>>>>>>> Next, I will try to let swift running on Amazon EC2.
>>>>>>>>>> Can you exercise the cluster with an interesting workflow?
>>>>>>>>> Yes, Is there any complex sample/tools i can use (rahter than
>>>>>>>>> first.swift) to test swift performance? Is there any benchmark
>>>>>>>>> available i can compare with?
>>>>>>>>>> How large of a cluster can you assemble in a Nimbus workspace ?
>>>>>>>>> Since the vm-image i use to test 'swift' is based on NFS shared
>>>>>>>>> file system, the performance may not be satisfiable if the we
>>>>>>>>> have a large scale of cluster. After I got the swift running on
>>>>>>>>> Amazon EC2, I will try to make a dedicate vm-image by using
>>>>>>>>> GPFS or any other shared file system you recommended.
>>>>>>>>>> Can you aggregate VM's from a few different physical clusters
>>>>>>>>>> into one Nimbus workspace?
>>>>>>>>> I don't think so. Tim may make commit on it.
>>>>>>>> There is some work going on right now making auto-configuration
>>>>>>>> easier to do
>>>>>>>> over multiple clusters (that is possible now, it's just very
>>>>>>>> 'manual' and
>>>>>>>> non-ideal unlike with one physical cluster). You wouldn't
>>>>>>>> really want to do NFS
>>>>>>>> across a WAN, though.
>>>>>>> Indeed. Now that I think this through more clearly, one workspace
>>>>>>> == one cluster == one Swift "site", so we could aggregate the
>>>>>>> resources of multiple workspaces through Swift to execute a
>>>>>>> multi-site workflow.
>>>>>>> - Mike
>>>>>>>>>> What's the largest cluster you can assemble with Nimbus?
>>>>>>>>> I am not quite sure,I will do some test onto it soon. since it
>>>>>>>>> is a EC2-like cloud, it should easily be configured as a
>>>>>>>>> cluster with hundreds of nodes. Tim may make commit on it.
>>>>>>>> I've heard of EC2 deployments in the 1000s at once, it's up to
>>>>>>>> your EC2 account
>>>>>>>> limitations (they seem pretty efficient with making your quota
>>>>>>>> ever-higher).
>>>>>>>> Nimbus installation at Teraport maxes out at 16, there are other
>>>>>>>> 'science
>>>>>>>> clouds' but I don't know their node numbers. EC2 is the place
>>>>>>>> where you will
>>>>>>>> be able to really test scaling something.
>>>>>>>> Tim
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
