[Swift-devel] Condor-G test on UJ-OSG site
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May 11 13:07:02 CDT 2009
On Mon, 2009-05-11 at 12:59 -0500, Zhao Zhang wrote:
> Hi, Ben
> Ben Clifford wrote:
> > On Fri, 8 May 2009, Zhao Zhang wrote:
> >> So, for the remote job manger, I could use pbs, condor, fork or SGE which ever
> >> is available on the remote site, right?
> > Yes. You must use whichever is installed on the remote site. For OSG thats
> > what swift-osg-ress-site-catalog tells you.
> Yes, for most of the time, it is correct. Here is a case: FLTECH site.
> In the site information web site, it says both condor and fork are
> available,
Fork should always be available, but it's not something you run cluster
jobs with.
> http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=322#SITELISTING,
> and swift-osg-ress-site-catalog chose condor as the default job manager.
> But I couldn't run any job there with condor job manager,
Why is that?
>  while if I use
> fork, jobs were running. Again, I am
> attaching the sites.xml file.
> zhao
> [zzhang at tp-grid1 condor-g]$ cat FLTECH.xml
> <config>
>   <!-- FLTECH -->
>   <pool handle="FLTECH" >
>     <gridftp  url="gsiftp://uscms1.fltech-grid3.fit.edu/" />
>     <execution  provider="condor" />
>     <workdirectory >/mnt/nas0/OSG/DATA/osg/tmp/FLTECH</workdirectory>
>     <profile namespace="globus" key="jobType">grid</profile>
>     <profile namespace="globus" key="gridResource">gt2
> uscms1.fltech-grid3.fit.edu/jobmanager-fork</profile>
>   </pool>
> </config>
