[Swift-devel] Re: What is best OSG site test suite ?
    Jing Tie
    tiejing at gmail.com
    Fri May  8 16:52:09 CDT 2009
Hi Zhao,
There are two problems:
1. some sites haven't finished all the tests when you run
"find_failure.pl". (the tool takes 2 - 10 mins depending on the sits)
If some site hasn't finished all the tests, just re-execute this
script later. But if some site takes too long time, it might indicate
some problems (e.g. gridftp).
2. test suit contains testing a monitoring tool "Monalisa" which may
not useful here.
So I delete "Monalisa" one, and also print out the status for all the
sites each time you run "find_failure.pl". A newer version is at
http://ci.uchicago.edu/~jtie/ts/test_osg_ce_0.1.tar.gz
Best,
Jing
On Fri, May 8, 2009 at 11:47 AM, Zhao Zhang <zhaozhang at uchicago.edu> wrote:
> Hi, Jing
> I tried the test_osg_ce tool out. I made two runs there,
> /home/zzhang/test_osg_ce/200958-10:39:37 is the latter one.
> For this test, no site showed in ce.pass. I am trying to figure out the
> error for each site, could you help me point out the
> reason for error? I mean how to interpret the result file. Also, I am
> attaching part of the ce.fail file of the first site.
> best wishes
> zhao
> ----------------------- AGLT2: gate01.aglt2.org -----------------------
> Checking for a running gatekeeper:
> <RESULTS> 1; port 2119
> <STATUS> 1
> Checking remote host uptime:
> <RESULTS> 1
>  11:39:50 up 4 days, 12:51,  1 user,  load average: 1.18, 1.21, 1.22
> <STATUS> 1
> Checking for GLOBUS_LOCATION:
> <RESULTS> /opt/OSG100/globus
> <STATUS> 1
> Checking expiration date of remote host certificate:
> <RESULTS> Mar 24 17:17:48 2010 GMT
> <STATUS> 1
> Checking for gatekeeper configuration file:
> <RESULTS> 1
>  /opt/OSG100/globus/etc/globus-gatekeeper.conf
> <STATUS> 1
> Checking users in grid-mapfile, if none must be using Prima:
> <RESULTS> usatlas1,usatlas3,usatlas4,usatlas5
> <STATUS> 1
> Checking for remote globus-sh-tools-vars.sh:
> <RESULTS> 1
> <STATUS> 1
> Checking configured grid services:
> <RESULTS> PASS
>  jobmanager,jobmanager-condor,jobmanager-fork,jobmanager-managedfork
> <STATUS> 1
> Checking for OSG osg-attributes.conf:
> <RESULTS> 1
> <STATUS> 1
> Checking scheduler types associated with remote jobmanagers:
> <RESULTS> 1
>  jobmanager is of type managedfork
>  jobmanager-condor is of type condor
>  jobmanager-fork is of type managedfork
>  jobmanager-managedfork is of type managedfork
> <STATUS> 1
> Checking for paths to binaries of remote schedulers:
> <RESULTS> 1
>  Path to condor binaries is /opt/condor/bin
>  Path to managedfork binaries is .
> <STATUS> 1
> Checking remote scheduler status:
> <RESULTS> 1
>  condor : 14 jobs running, 0 jobs idle/pending
> <STATUS> 1
> Checking if Globus is deployed from the VDT:
> <RESULTS> 1; version 1.10.1j
> <STATUS> 1
> Checking for OSG version:
> <RESULTS> 1; version 1.0.0
> <STATUS> 1
> Checking for OSG grid3-user-vo-map.txt:
> <RESULTS> 1
>  usatlas users: usatlas1,usatlas2,usatlas3,usatlas4
>  gridex users: gridex
>  ops users: ops
>  mis users: mis
>  osg users: osg
> <STATUS> 1
> Checking for OSG site name:
> <RESULTS> AGLT2
> <STATUS> 1
> Checking for OSG $GRID3 definition:
> <STATUS> 1
> Checking for OSG $OSG_GRID definition:
> <RESULTS> /afs/atlas.umich.edu/OSGWN
> <STATUS> 1
> Checking for OSG $APP definition:
> <RESULTS> /atlas/data08/OSG/APP
> <STATUS> 1
> Checking for OSG $DATA definition:
> <RESULTS> /atlas/data08/OSG/DATA
> <STATUS> 1
> Checking for OSG $TMP definition:
> <STATUS> 1
> Checking for OSG $WNTMP definition:
> <RESULTS> /tmp
> <STATUS> 1
> Checking for OSG $APP available space:
> <RESULTS> 2032.963 GB
> <STATUS> 1
> Checking for OSG $DATA available space:
> <STATUS> 1
> Checking for OSG $TMP available space:
> <STATUS> 1
> Checking for OSG additional site-specific variable definitions:
> <RESULTS> 1
>  <No Location List Name>
>   ATLAS_APP prod /atlas/data08/OSG/APP/atlas_app
>   ATLAS_DATA prod /atlas/data08/OSG/DATA/atlas_data
> <STATUS> 1
> Checking for OSG execution jobmanager(s):
> <RESULTS> gate01.aglt2.org/jobmanager-condor
> <STATUS> 1
> Checking for OSG utility jobmanager(s):
> <STATUS> 1
> Checking for OSG sponsoring VO:
> <RESULTS> usatlas:80 local:20
> <STATUS> 1
> Checking for OSG policy expression:
> <RESULTS> NONE
> <STATUS> 1
> Checking for OSG setup.sh:
> <RESULTS> 1
> <STATUS> 1
> Checking for OSG $Monalisa_HOME definition:
> <RESULTS> /opt/osg-ce-1.0.0-r2/MonaLisa
> <STATUS> 1
> Checking for MonALISA configuration:
> <RESULTS> 0
>  Can't obtain ml_env
> <STATUS> 0
> Checking for a running MonALISA:
> <RESULTS> 0
>  MonALISA does not appear to be running
> <STATUS> 1
> Checking for a running GANGLIA gmond daemon:
> <RESULTS> 1 (pid 8095 ...)
>  /usr/sbin/gmond
>  name = "swap_free"
>  owner = "University of Michigan"
>  url = "https://hep.pa.msu.edu/twiki/bin/view/AGLT2"
> <STATUS> 1
> Checking for a running GANGLIA gmetad daemon:
> <RESULTS> 0
>  gmetad does not appear to be running
> <STATUS> 1
> Checking for a running gsiftp server:
> <RESULTS> 1; port 2811
> <STATUS> 1
> Jing Tie wrote:
>> On Fri, May 8, 2009 at 6:21 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> Jing, Ben, thanks very much for the tips.
>>> Jing, was site_verify.pr the older test suite was done by Jens as part of
>>> VDS?
>> I think site_verify scanner is a part of OSG MIS, and the author is
>> Craig Prescott.
>> VORS (http://scan.grid.iu.edu/) runs the script in MIS VO and shows
>> the testing results. But VORS has problems since if a site doesn't
>> support MIS VO, the site cannot be seen on the VORS. So GOC is
>> replacing VORS with RSV.
>>> Also, how would you compare test_osg_ce with osg-vo-test?
>> osg-vo-test contains one more thing than test_osg_ce: resource
>> selection info such as free slot and cpu type. But it selects sites
>> from dynamic VORS which has the problem described above, while
>> test_osg_ce selects from a static sites list.
>> RSV starts recently, so I am not familiar with it. But I think RSV
>> contains the best list of sites in a chosen VO.
>> Best,
>> Jing
>>> Mats, do you have anything for such site testing?
>>> Zhao, I suggest you start with test_osg_ce.
>>> - Mike
>>> On 5/8/09 12:43 AM, Jing Tie wrote:
>>>> Hi Mike,
>>>> I think others might have better tools, but I can list three here as
>>>> possible options.
>>>> The first one is "osg-vo-test" developed by Chris Green. It lists
>>>> probing results for all the sites in a certain VO (e.g.
>>>> http://www.ci.uchicago.edu/~jtie/osg-vo-test/osg_summary/2008727-19:20:43.html).
>>>> I attached his announcement about this tool in the end of the email.
>>>> The second one "test_osg_ce" is used by Zhengxiong, Xi and me a lot.
>>>> It's a simple package that I developed based on site_verify.pl. It
>>>> runs the script (check authentication, globus-job-run, gridftp, user
>>>> directory...) for each site in a user configuration file, and print
>>>> out the good ones. I have attached it in the email.
>>>> The last one is RSV developed by GOC. It runs similar scripts as
>>>> site_verify.pl by system administrators, and reports to a centralized
>>>> server periodically. You can find it on MyOSG
>>>> (http://myosg.grid.iu.edu/about). I think it won't be hard to setup an
>>>> independent version for user.
>>>> Hope it helps,
>>>> Jing
>>>> Email from Chris Green:
>>>> Hi,
>>>> I am happy to announce the first general release of an extensible
>>>> VO-centric site testing kit, "osg-vo-test".
>>>> To explain why you might be interested in this package, I quote from the
>>>> overview
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Overview>
>>>> on the package's home TWiki page
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>:
>>>> This package is an attempt to allow /application owners/ (by which I
>>>> mean people responsible for running an application on OSG) to
>>>> characterize OSG sites from the point of view of being able to run your
>>>> application. Questions can be asked of each site in multiple ways, for
>>>> instance:
>>>>  * Command line, eg:
>>>>    ping my-ce.my-domain
>>>>  * Fork job, eg:
>>>>    globus-job-run my-ce.my-domain /usr/bin/printenv
>>>>  * Batch job via CondorG.
>>>>  * ReSS, the *Re*source *S*election *S*ystem.
>>>>  * VORS, the *VO* *R*esource *S*elector.
>>>> The results are presented primarily in the form of an HTML table
>>>> <http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.html>
>>>> with results columns (possibly multiple columns per test), with a link
>>>> to more detailed information for the test.
>>>> In addition, the summary results are available in .CSV format
>>>> <http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.csv>
>>>> for machine readability; a true XML format may be forthcoming if there
>>>> is enough demand.
>>>> The application owner can write new test modules inheriting from the
>>>> old; for more details, see Making your own module
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Making_your_own_test_module>.
>>>> In addition, existing tests are highly configurable and allow for the
>>>> addition of new results columns with minimal effort; for a quick
>>>> example, see the Getting Started
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>
>>>> section; and also the detail
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#More_Details>
>>>> section.
>>>> It is extremely straightforward, for example, to test basic
>>>> authorization at a site from the point of view of your own voms-proxy;
>>>> and other tests are showcased in example control scripts; or provided as
>>>> standalone test modules. The example summary page
>>>> shows a wide range of tests of which this extensible system is capable.
>>>> Please, visit the package's home TWiki page
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>,
>>>> download
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Download_Source>
>>>> the source; use
>>>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>;
>>>> and give feedback <mailto:osg-user-group?subject=osg-vo-tests>. The aim
>>>> is to make it easy for application owners to put together their own
>>>> suite or suites of tests to analyze sites across the OSG from the
>>>> perspective of the needs of their own application(s) without having to
>>>> re-invent the wheel to interrogate all the different sources of
>>>> information about OSG sites.
>>>> On Thu, May 7, 2009 at 2:47 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>>>> Hi All,
>>>>> Many of you have developed, or use, various test suites to probe the
>>>>> sites
>>>>> of an OSG VO to see if basic authentication, job execution, and data
>>>>> transfer work for a given user (cert).
>>>>> Can you let us know, on swift-devel, what test suite you use, and what
>>>>> you
>>>>> suggest that the Swift team use, as part of a Swift verification test
>>>>> suite
>>>>> that reports what sites Swift does (and does not) work on?
>>>>> In other words, once a user probes OSG to create a Swift sites file, it
>>>>> would be useful to test if the basic services are working for the test
>>>>> user,
>>>>> before testing at a higher level through Swift.
>>>>> Thanks,
>>>>> Mike
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
