[Swift-devel] SWIFT_JOBDIR_PATH env not passed on remote sites
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  8 16:23:15 CDT 2009
Does it also happen if you use GT2 instead of PBS?
On Fri, 2009-05-08 at 15:46 -0500, Allan Espinosa wrote:
> Hi,
> SWIFT_JOBDIR_PATH only works in local executions.  it looks like the
> environment variable is not being passed for remote job submissions:
> sites.xml:
> <config>
>   <pool handle="TERAPORT" sysinfo="INTEL32::LINUX">
>     <execution provider="pbs" url="none" />
>     <profile namespace="globus" key="queue">fast</profile>
>     <gridftp url="local://localhost" />
>     <workdirectory >/home/aespinosa/workflows/jobdirpath/sitedir</workdirectory>
>     <profile namespace="env"
> key="SWIFT_JOBDIR_PATH">/home/aespinosa/workflows/localnode</profile>
>   </pool>
> </config>
> resulting wrapper log:
> Progress  2009-05-08 15:33:31.258501000-0500  LOG_START
> _____________________________________________________________________________
>         Wrapper
> Job directory mode is: link on shared filesystem
> DIR=jobs/v/cat-vbmpqiaj
> EXEC=/bin/cat
> STDIN=
> STDOUT=061-cattwo.out
> STDERR=stderr.txt
> DIRS=
> INF=061-cattwo.1.in|061-cattwo.2.in
> OUTF=061-cattwo.out
> KICKSTART=
> ARGS=061-cattwo.1.in 061-cattwo.2.in
> ARGC=2
> Progress  2009-05-08 15:33:31.277785000-0500  CREATE_JOBDIR
> Created job directory: jobs/v/cat-vbmpqiaj
> Progress  2009-05-08 15:33:31.289956000-0500  CREATE_INPUTDIR
> Progress  2009-05-08 15:33:31.294467000-0500  LINK_INPUTS
> Linked input: /home/aespinosa/workflows/jobdirpath/sitedir/061-cattwo-20090508-1533-x71gz29g/shared/061-cattwo.1.in
> to jobs/v/cat-vbmpqiaj/061-cattwo.1.in
> Linked input: /home/aespinosa/workflows/jobdirpath/sitedir/061-cattwo-20090508-1533-x71gz29g/shared/061-cattwo.2.in
> to jobs/v/cat-vbmpqiaj/061-cattwo.2.in
> Progress  2009-05-08 15:33:31.327217000-0500  EXECUTE
> Moving back to workflow directory
> Progress  2009-05-08 15:33:31.338850000-0500  EXECUTE_DONE
> Job ran successfully
> Progress  2009-05-08 15:33:31.343910000-0500  COPYING_OUTPUTS
> Progress  2009-05-08 15:33:31.373251000-0500  RM_JOBDIR
> Progress  2009-05-08 15:33:31.383733000-0500  TOUCH_SUCCESS
> Progress  2009-05-08 15:33:31.398652000-0500  END
> the directory "localnode" is also not created.  Test peformed using
> 061-cattwo.  my testcase script is in ~aespinosa/workflows/jobdirpath
> [aespinosa at tp-login1 jobdirpath]$ ./runtest.sh
> Swift svn swift-r2911 cog-r2394
> RunID: remoterun
> Progress:  uninitialized:1
> Progress:  Active:1
> Final status:  Finished successfully:1
> Remote test FAIL
> RunID: localrun
> Progress:
> Local test PASS
> -Allan
