[Swift-devel] Re: What is best OSG site test suite ?
    Jing Tie
    tiejing at gmail.com
    Fri May  8 11:34:17 CDT 2009
On Fri, May 8, 2009 at 6:21 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Jing, Ben, thanks very much for the tips.
> Jing, was site_verify.pr the older test suite was done by Jens as part of
> VDS?
I think site_verify scanner is a part of OSG MIS, and the author is
Craig Prescott.
VORS (http://scan.grid.iu.edu/) runs the script in MIS VO and shows
the testing results. But VORS has problems since if a site doesn't
support MIS VO, the site cannot be seen on the VORS. So GOC is
replacing VORS with RSV.
> Also, how would you compare test_osg_ce with osg-vo-test?
osg-vo-test contains one more thing than test_osg_ce: resource
selection info such as free slot and cpu type. But it selects sites
from dynamic VORS which has the problem described above, while
test_osg_ce selects from a static sites list.
RSV starts recently, so I am not familiar with it. But I think RSV
contains the best list of sites in a chosen VO.
Best,
Jing
> Mats, do you have anything for such site testing?
> Zhao, I suggest you start with test_osg_ce.
> - Mike
> On 5/8/09 12:43 AM, Jing Tie wrote:
>> Hi Mike,
>> I think others might have better tools, but I can list three here as
>> possible options.
>> The first one is "osg-vo-test" developed by Chris Green. It lists
>> probing results for all the sites in a certain VO (e.g.
>> http://www.ci.uchicago.edu/~jtie/osg-vo-test/osg_summary/2008727-19:20:43.html).
>> I attached his announcement about this tool in the end of the email.
>> The second one "test_osg_ce" is used by Zhengxiong, Xi and me a lot.
>> It's a simple package that I developed based on site_verify.pl. It
>> runs the script (check authentication, globus-job-run, gridftp, user
>> directory...) for each site in a user configuration file, and print
>> out the good ones. I have attached it in the email.
>> The last one is RSV developed by GOC. It runs similar scripts as
>> site_verify.pl by system administrators, and reports to a centralized
>> server periodically. You can find it on MyOSG
>> (http://myosg.grid.iu.edu/about). I think it won't be hard to setup an
>> independent version for user.
>> Hope it helps,
>> Jing
>> Email from Chris Green:
>> Hi,
>> I am happy to announce the first general release of an extensible
>> VO-centric site testing kit, "osg-vo-test".
>> To explain why you might be interested in this package, I quote from the
>> overview
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Overview>
>> on the package's home TWiki page
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>:
>> This package is an attempt to allow /application owners/ (by which I
>> mean people responsible for running an application on OSG) to
>> characterize OSG sites from the point of view of being able to run your
>> application. Questions can be asked of each site in multiple ways, for
>> instance:
>>   * Command line, eg:
>>     ping my-ce.my-domain
>>   * Fork job, eg:
>>     globus-job-run my-ce.my-domain /usr/bin/printenv
>>   * Batch job via CondorG.
>>   * ReSS, the *Re*source *S*election *S*ystem.
>>   * VORS, the *VO* *R*esource *S*elector.
>> The results are presented primarily in the form of an HTML table
>> <http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.html>
>> with results columns (possibly multiple columns per test), with a link
>> to more detailed information for the test.
>> In addition, the summary results are available in .CSV format
>> <http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.csv>
>> for machine readability; a true XML format may be forthcoming if there
>> is enough demand.
>> The application owner can write new test modules inheriting from the
>> old; for more details, see Making your own module
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Making_your_own_test_module>.
>> In addition, existing tests are highly configurable and allow for the
>> addition of new results columns with minimal effort; for a quick
>> example, see the Getting Started
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>
>> section; and also the detail
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#More_Details>
>> section.
>> It is extremely straightforward, for example, to test basic
>> authorization at a site from the point of view of your own voms-proxy;
>> and other tests are showcased in example control scripts; or provided as
>> standalone test modules. The example summary page
>> shows a wide range of tests of which this extensible system is capable.
>> Please, visit the package's home TWiki page
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>,
>> download
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Download_Source>
>> the source; use
>> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>;
>> and give feedback <mailto:osg-user-group?subject=osg-vo-tests>. The aim
>> is to make it easy for application owners to put together their own
>> suite or suites of tests to analyze sites across the OSG from the
>> perspective of the needs of their own application(s) without having to
>> re-invent the wheel to interrogate all the different sources of
>> information about OSG sites.
>> On Thu, May 7, 2009 at 2:47 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> Hi All,
>>> Many of you have developed, or use, various test suites to probe the
>>> sites
>>> of an OSG VO to see if basic authentication, job execution, and data
>>> transfer work for a given user (cert).
>>> Can you let us know, on swift-devel, what test suite you use, and what
>>> you
>>> suggest that the Swift team use, as part of a Swift verification test
>>> suite
>>> that reports what sites Swift does (and does not) work on?
>>> In other words, once a user probes OSG to create a Swift sites file, it
>>> would be useful to test if the basic services are working for the test
>>> user,
>>> before testing at a higher level through Swift.
>>> Thanks,
>>> Mike
