[Swift-devel] Swift-issues (PBS+NFS Cluster)
    yizhu
    yizhu at cs.uchicago.edu
    Wed May  6 22:10:38 CDT 2009
problem solved.
i immigrate all of my work from my  laptop to ci.uchicago.edu server and
then everything works.
-Yi
yizhu wrote:
> Hi all
> I tried running swift-0.8 over  Nimbus Cloud (PBS+NFS), and configured
> sites.xml and tc.data accordingly.[1]
> When i tried to run "$swift first.swift", it  stuck on "Submitting:1"
> phase[2], (keep repeated showing "Progress:Submitting:1" and  never
> return).
> Then I ssh to pbs_server to check the server log[3] and found that the
> job has been enqueued, ran, and successfully dequeued. I also check the
> queue status[4] when this job is running and found that the output_path
> is "/dev/null" somewhat i don't expected. ( The working directory of
> swift is "/home/jobrun".
> I think the problem might be the pbs_server failed to return the output
> to the correct path (btw. what the output_path suppose to be, the same
> work_directory of swift?), or anyone has a better idea?
> Many Thanks.
> -Yi
> [1]----sites.xml
>  <pool handle="nb_basecluster">
>     <gridftp url="gsiftp://tp-x001.ci.uchicago.edu" />
>     <execution
> url="https://tp-x001.ci.uchicago.edu:8443/wsrf/services/ManagedJobFactoryService"
> jobManager="PBS" provider="gt4" />
>     <workdirectory >/home/jobrun</workdirectory>
>   </pool>
> ----tc.data
> nb_basecluster     echo         /bin/echo    INSTALLED
> INTEL32::LINUX    null
> nb_basecluster     cat         /bin/cat    INSTALLED
> INTEL32::LINUX    null
> nb_basecluster     ls         /bin/ls        INSTALLED
> INTEL32::LINUX    null
> nb_basecluster     grep         /bin/grep    INSTALLED
> INTEL32::LINUX    null
> nb_basecluster     sort         /bin/sort    INSTALLED
> INTEL32::LINUX    null
> nb_basecluster     paste         /bin/paste    INSTALLED
> INTEL32::LINUX    null
> [2]
> yizhu at ubuntu:~/swift-0.8/examples/swift$ swift -d first.swift
> Recompilation suppressed.
> Using sites file: /home/yizhu/swift-0.8/bin/../etc/sites.xml
> Using tc.data: /home/yizhu/swift-0.8/bin/../etc/tc.data
> Setting resources to: {nb_basecluster=nb_basecluster}
> Swift 0.8 swift-r2448 cog-r2261
> RUNID id=tag:benc at ci.uchicago.edu,2007:swift:run:20090506-1912-zqd8t5hg
> RunID: 20090506-1912-zqd8t5hg
> closed org.griphyn.vdl.mapping.RootDataNode identifier
> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000001
> type string value=Hello, world! dataset=unnamed SwiftScript value (closed)
> ROOTPATH
> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000001
> path=$
> VALUE
> VALUE=Hello, world!
> ROOTPATH
> path=$
> VALUE
> VALUE=Hello, world!
> NEW
> id=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000001
> Found mapped data org.griphyn.vdl.mapping.RootDataNode identifier
> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000002
> type messagefile with no value at dataset=outfile (not closed).$
> NEW
> id=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000002
> Progress:
> PROCEDURE thread=0 name=greeting
> PARAM thread=0 direction=output variable=t
> provenanceid=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000002
> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000003
> type string value=hello.txt dataset=unnamed SwiftScript value (closed)
> ROOTPATH
> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090506-1912-lxp69uu2:720000000003
> path=$
> VALUE
> VALUE=hello.txt
> ROOTPATH
> path=$
> VALUE
> VALUE=hello.txt
> START thread=0 tr=echo
> Sorted: [nb_basecluster:0.000(1.000):0/1 overload: 0]
> Rand: 0.6583597597672994, sum: 1.0
> Next contact: nb_basecluster:0.000(1.000):0/1 overload: 0
> Progress:  Initializing site shared directory:1
> START host=nb_basecluster - Initializing shared directory
> multiplyScore(nb_basecluster:0.000(1.000):1/1 overload: 0, -0.01)
> Old score: 0.000, new score: -0.010
> No global submit throttle set. Using default (100)
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174935) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:-0.010(0.994):1/1 overload: 0, 0.01)
> Old score: -0.010, new score: 0.000
> multiplyScore(nb_basecluster:0.000(1.000):1/1 overload: 0, 0.1)
> Old score: 0.000, new score: 0.100
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174935) Completed.
> Waiting: 0, Running: 0. Heap size: 75M, Heap free: 63M, Max heap: 720M
> multiplyScore(nb_basecluster:0.100(1.060):1/1 overload: 0, -0.2)
> Old score: 0.100, new score: -0.100
> Task(type=FILE_TRANSFER, identity=urn:0-1-1241655174938) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:-0.100(0.943):1/1 overload: 0, 0.2)
> Old score: -0.100, new score: 0.100
> multiplyScore(nb_basecluster:0.100(1.060):1/1 overload: 0, 0.1)
> Old score: 0.100, new score: 0.200
> Task(type=FILE_TRANSFER, identity=urn:0-1-1241655174938) Completed.
> Waiting: 0, Running: 0. Heap size: 75M, Heap free: 60M, Max heap: 720M
> multiplyScore(nb_basecluster:0.200(1.124):1/1 overload: 0, -0.2)
> Old score: 0.200, new score: 0.000
> Task(type=FILE_TRANSFER, identity=urn:0-1-1241655174940) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:0.000(1.000):1/1 overload: 0, 0.2)
> Old score: 0.000, new score: 0.200
> multiplyScore(nb_basecluster:0.200(1.124):1/1 overload: 0, 0.1)
> Old score: 0.200, new score: 0.300
> Task(type=FILE_TRANSFER, identity=urn:0-1-1241655174940) Completed.
> Waiting: 0, Running: 0. Heap size: 75M, Heap free: 59M, Max heap: 720M
> multiplyScore(nb_basecluster:0.300(1.192):1/1 overload: 0, -0.01)
> Old score: 0.300, new score: 0.290
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174942) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:0.290(1.185):1/1 overload: 0, 0.01)
> Old score: 0.290, new score: 0.300
> multiplyScore(nb_basecluster:0.300(1.192):1/1 overload: 0, 0.1)
> Old score: 0.300, new score: 0.400
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174942) Completed.
> multiplyScore(nb_basecluster:0.400(1.264):1/1 overload: 0, -0.01)
> Old score: 0.400, new score: 0.390
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174944) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:0.390(1.256):1/1 overload: 0, 0.01)
> Old score: 0.390, new score: 0.400
> multiplyScore(nb_basecluster:0.400(1.264):1/1 overload: 0, 0.1)
> Old score: 0.400, new score: 0.500
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174944) Completed.
> multiplyScore(nb_basecluster:0.500(1.339):1/1 overload: 0, -0.01)
> Old score: 0.500, new score: 0.490
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174946) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:0.490(1.332):1/1 overload: 0, 0.01)
> Old score: 0.490, new score: 0.500
> multiplyScore(nb_basecluster:0.500(1.339):1/1 overload: 0, 0.1)
> Old score: 0.500, new score: 0.600
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174946) Completed.
> END host=nb_basecluster - Done initializing shared directory
> THREAD_ASSOCIATION jobid=echo-kfecpfaj thread=0-1 host=nb_basecluster
> replicationGroup=jfecpfaj
> Progress:  Stage in:1
> START jobid=echo-kfecpfaj host=nb_basecluster - Initializing directory
> structure
> START path= dir=first-20090506-1912-zqd8t5hg/shared - Creating directory
> structure
> multiplyScore(nb_basecluster:0.600(1.419):1/1 overload: 0, -0.01)
> Old score: 0.600, new score: 0.590
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174948) setting status
> to Submitting
> to Submitted
> to Active
> to Completed
> multiplyScore(nb_basecluster:0.590(1.411):1/1 overload: 0, 0.01)
> Old score: 0.590, new score: 0.600
> multiplyScore(nb_basecluster:0.600(1.419):1/1 overload: 0, 0.1)
> Old score: 0.600, new score: 0.700
> Task(type=FILE_OPERATION, identity=urn:0-1-1241655174948) Completed.
> END jobid=echo-kfecpfaj - Done initializing directory structure
> START jobid=echo-kfecpfaj - Staging in files
> END jobid=echo-kfecpfaj - Staging in finished
> JOB_START jobid=echo-kfecpfaj tr=echo arguments=[Hello, world!]
> tmpdir=first-20090506-1912-zqd8t5hg/jobs/k/echo-kfecpfaj
> host=nb_basecluster
> jobid=echo-kfecpfaj task=Task(type=JOB_SUBMISSION,
> identity=urn:0-1-1241655174950)
> multiplyScore(nb_basecluster:0.700(1.503):1/1 overload: 0, -0.2)
> Old score: 0.700, new score: 0.500
> Task(type=JOB_SUBMISSION, identity=urn:0-1-1241655174950) setting status
> to Submitting
> Submitting task: Task(type=JOB_SUBMISSION, identity=urn:0-1-1241655174950)
> <startTime name="submission">1241655180260</startTime>
> <startTime name="createManagedJob">1241655180623</startTime>
> <endTime name="createManagedJob">1241655181975</endTime
> Task submitted: Task(type=JOB_SUBMISSION, identity=urn:0-1-1241655174950)
> Progress:  Submitting:1
> ^C
> [3] see attachment
> [4]
> tp-x001 torque # qstat -f
> Job Id: 3.tp-x001.ci.uchicago.edu
>     Job_Name = STDIN
>     Job_Owner = jobrun at tp-x001.ci.uchicago.edu
>     job_state = R
>     queue = batch
>     server = tp-x001.ci.uchicago.edu
>     Checkpoint = u
>     ctime = Wed May  6 19:22:10 2009
>     Error_Path = tp-x001.ci.uchicago.edu:/dev/null
>     exec_host = tp-x002/0
>     Hold_Types = n
>     Join_Path = n
>     Keep_Files = n
>     Mail_Points = n
>     mtime = Wed May  6 19:22:10 2009
>     Output_Path = tp-x001.ci.uchicago.edu:/dev/null
>     Priority = 0
>     qtime = Wed May  6 19:22:10 2009
>     Rerunable = True
>     Resource_List.neednodes = 1
>     Resource_List.nodect = 1
>     Resource_List.nodes = 1
>     Shell_Path_List = /bin/sh
>     substate = 40
>     Variable_List = PBS_O_HOME=/home/jobrun,PBS_O_LOGNAME=jobrun,
>     PBS_O_PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sb
>     in:/opt/bin,PBS_O_SHELL=/bin/bash,PBS_SERVER=tp-x001.ci.uchicago.edu,
>     PBS_O_HOST=tp-x001.ci.uchicago.edu,
>     PBS_O_WORKDIR=/home/jobrun/first-20090506-1922-xaandi54,
>     PBS_O_QUEUE=batch
>     euser = jobrun
>     egroup = users
>     hashname = 3.tp-x001.c
>     queue_rank = 2
>     queue_type = E
>     comment = Job started on Wed May 06 at 19:22
>     etime = Wed May  6 19:22:10 2009
> tp-x001 torque #
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
