[Swift-devel] Problem on oops run: Java out of memory
Mihael Hategan hategan at mcs.anl.gov
Tue Mar 31 10:11:39 CDT 2009
What's your workflow, and how much memory are you running swift with?
On Tue, 2009-03-31 at 07:23 -0500, Michael Wilde wrote:
> There is a new way to limit the number of jobs that a for-loop will
> allow to be active at once.  Thats in the user guide, and it defaults I
> think to 1024.
> I dont know if there is a per-site limit.
> So it sounds like there may be a swift bug here.  You should report this
> one to swift-devel after rsyncying your log file to the swift log
> repository as per the user guide.
> Sounds like nice progress!
> - Mike
> On 3/31/09 1:28 AM, Glen Hocky wrote:
> > Hi Mike,
> > I was able to successfully modify everything so that temperature sweeps
> > work correctly on teraport.
> > the main problem i've run up against is that i would like to test this
> > out with a lot of jobs, but i got
> >> Uncaught exception: java.lang.OutOfMemoryError: Java heap space in
> >> kernel:named @ vdl-int.k
> >>         at java.util.HashMap.addEntry(HashMap.java:753)
> >>         at java.util.HashMap.put(HashMap.java:385)
> >>         at
> >> org.globus.cog.karajan.arguments.NamedArgumentsImpl.add(NamedArgumentsImpl.java:83)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.initializeArgs(AbstractSequentialWithArguments.java:158)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.pre(AbstractSequentialWithArguments.java:138)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:62)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
> >>         at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
> >>         at
> >> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
> >>         at
> >> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
> >>         at
> >> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
> >>         at
> >> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> > which makes sense since I was submitting thousands of jobs
> > i don't see a param to limit the max on a given site to N. do you know
> > of one?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
