[Swift-devel] "getValue called in an external dataset" issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Mar 24 15:59:15 CDT 2009
Hi, I keep getting this message "getValue called in an external dataset"
when I run the following swift script. I know it comes from the external
data type, could anyone point me the error in the script? The "external
bout" is the external data file. Thanks.
type Mol {}
type Bin {}
type Common {}
type DOCKOut {}
type Molout{}
type DockRunSummary {}
type file {}
(external bout)bcast (Bin binary, Common flex_def, Common flex_tbl,
Common grid_bmp, Common
grid_in, Common grid_nrg, Common grid_out, Common rec_box, Common receptor,
Common sample_grid, Common selected_spheres, Common template_in, Common vdw,
Common awkscript)
        app {
            bcast @filename(binary)  @filename(flex_def)
            @filename(flex_tbl) @filename(grid_bmp) @filename(grid_in)
            @filename(grid_nrg) @filename(grid_out) @filename(rec_box)
            @filename(receptor) @filename(sample_grid)
            @filename(selected_spheres)
            @filename(template_in) @filename(vdw) @filename(awkscript);
app (DOCKOut ofile) rundock_zhao (Mol molfile, Bin binary, Common
flex_def, Common
flex_tbl, Common grid_bmp, Common grid_in, Common grid_nrg, Common grid_out,
Common rec_box, Common receptor, Common sample_grid, Common
selected_spheres,
Common template_in, Common vdw, Common awkscript, external bout)
       rundock_zhao @filename(molfile) @filename(binary) @filename(flex_def)
stdout=@filename(ofile);
app (DockRunSummary finalfile) sumdockresults(DOCKOut r[] )
       summary @filenames(r) stdout=@filename(finalfile);
Mol texts[] <filesys_mapper;location="input/", suffix=".mol2">;
(DOCKOut result[])doall(Mol texts[])
  Bin binary <"common/dock6.O3.cn">;
  Common flex_def <"common/flex.defn">;
  Common flex_tbl <"common/flex_drive.tbl">;
  Common grid_bmp <"common/grid.bmp">;
  Common grid_in <"common/grid.in">;
  Common grid_nrg <"common/grid.nrg">;
  Common grid_out <"common/grid.out">;
  Common rec_box <"common/rec_box.pdb">;
  Common receptor <"common/receptor_charged.mol2">;
  Common sample_grid <"common/sample_grid.in">;
  Common selected_spheres <"common/selected_spheres.sph">;
  Common template_in <"common/template.in">;
  Common vdw <"common/vdw_AMBER_parm99.defn">;
  Common awkscript <"common/awkscript">;
  external bout;
  bout=bcast(binary, flex_def, flex_tbl, grid_bmp, grid_in, grid_nrg,
grid_out, rec_box, receptor, sample_grid, selected_spheres, template_in,
vdw, awkscript);
  foreach p,i in texts {
      result[i] = rundock_zhao(p, binary, flex_def, flex_tbl, grid_bmp,
grid_in,
      grid_nrg, grid_out, rec_box, receptor, sample_grid,
selected_spheres, template_in, vdw, awkscript, bout);
// Main
DockRunSummary summary <"summary.txt">;
DOCKOut result[];
result=doall(texts);
summary = sumdockresults(result);
