[Swift-devel] could we set the job sequence without a file dependency?
Ben Clifford benc at hawaga.org.uk
Tue Mar 24 12:27:00 CDT 2009
On Tue, 24 Mar 2009, Ian Foster wrote:
> I raised a technical issue: people sometimes want to express sequencing that
> relates to external side effects (e.g., output). How do we do that? We can, as
> Ben suggests, introduce an artificial data dependency. Or, we can provide an
> operator that expresses the sequencing. Each have pros and cons:
I don't really thing (a lot of the time) that it is an artificial data
dependency - in Zhao and Mike's cases both, they have data dependencies.
> - The artificial data dependency is less clear in its semantics than the
> sequential operator
I think they both make one thing happen before the other. I don't think
either way is less clear.
> - The artificial data dependency requires that you modify procedures to
> sequence them
> - The artificial data dependency is a real pain to write if you have to do it
> a lot
disagree
> + The artificial data dependency may allow for finer control over what is
> sequenced
I think they're probably about equivalent.
> I couldn't care less whether Swift looks like PCN. But I do have that
> experience, and recall the considerable frustration of some users who wanted
> to ensure that activity X happened before activity Y (whether for side
> effects, or debugging) and had to go to great lengths to introduce artificial
> data dependencies to achieve that goal.
The sequencing-for-debugging thing is something I think that external
dependencies is perhaps wrong for. Not sure if putting an operator into
the language is the right way - we've talked about different
execution modes too, which might be a better thing to do.
