[Swift-devel] problems with external dependencies
    Ben Clifford
    benc at hawaga.org.uk
    Tue Mar 24 04:30:27 CDT 2009
On Mon, 23 Mar 2009, Michael Wilde wrote:
> out = ls("datadir/", sync);
This ls needs an absolute path - when it runs, it is in its own jobdir
which (deliberately) has none of the other files staged in.
You need to specify the absolute path to your data directory there.
One way to think of it is: rather than calling the directory 'sync', you
coul call it 'myDataDir' - that external variable represents the external
directory being created and passed around. But, because you have declared
that data 'external' that means Swift will never attempt to put you in the
right directory for access to that data or prepare any input files for you
or anything like that (indeed, your external data might not even be file
based - this was originally implemented for someone who wanted to do
database access, I think)
