[Swift-devel] problems with external dependencies
Ben Clifford
benc at hawaga.org.uk
Mon Mar 23 12:41:17 CDT 2009
On Mon, 23 Mar 2009, Michael Wilde wrote:
> I dont think what you have below works. Perhaps it was fooled by a prior
> existing datadir? When I change your path back to my local datadir, I get a
> failure in ls, because it runs before datadir exists.
It works on my laptop repeatably with present head, removing ls.out and
datadir/ in between runs.
Send me a run log and also a copy of the SwiftScript source code you are
running.
> I think the problem is that generate returns as soon as the foreach
> launches its echo apps, but before they run.
It shouldn't. If you have Swift >=r2734, you should see log lines with the
token STARTCOMPOUND and ENDCOMPOUND in them giving the timings.
