[Swift-devel] swift compilation error on compound expressions
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 23 08:46:20 CDT 2009
This occurs on an even simpler example. It doesnt seem to like:
   cond =  (st != "");
This script:
string st = "foo";
boolean cond;
cond =  (st != "");
gives:
sur$ swift tp2.swift
Could not start execution.
         Error reading source:  : unexpected character in markup >
(position: START_TAG seen ...<argument name="value">\n\t\t
    <>... @49:22)  :  : unexpected character in markup > (position:
START_TAG seen ...<argument name="value">\n\t\t                 <>...
@49:22)
On 3/23/09 8:30 AM, Michael Wilde wrote:
> This script:
>   string st = "foo";
>   string tu = "bar";
>   if  ((st != "") || (tu != ""))  {
>     if ((st != "") && (tu != "")) {
>       trace("sweep");
>     else {
>       trace("Error");
>   else {
>     trace("simple_loop");
> sur$
> gives:
> (position: START_TAG seen ...<vdl:getfieldvalue><vdlop:or>\n\t\t
> <>... @69:17)  :  : unexpected character in markup > (position:
> START_TAG seen ...<vdl:getfieldvalue><vdlop:or>\n\t\t            <>...
> @69:17)
> sur$ cat tparse.swift
> tparse.xml is:
> <program xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
>          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>          xmlns:xs="http://www.w3.org/2001/XMLSchema">
>   <variable name="st" type="string" xsi:nil="true"/>
>   <assign src="line 2">
>    <variableReference>st</variableReference>
>    <stringConstant>foo</stringConstant>
>   </assign>
>   <variable name="tu" type="string" xsi:nil="true"/>
>   <assign src="line 3">
>    <variableReference>tu</variableReference>
>    <stringConstant>bar</stringConstant>
>   </assign>
>   <if>
>     <or>
>       <cond op="!=">
>         <stringConstant></stringConstant>
>       </cond>
>       <cond op="!=">
>       </cond>
>     </or>
>     <then>
>       <if>
>         <and>
>           <cond op="!=">
>           </cond>
>           <cond op="!=">
>           </cond>
>         </and>
>         <then>
>           <call proc="trace" src="line 5">
>             <input><stringConstant>sweep</stringConstant></input>
>           </call>
>         </then>
>         <else>
>           <call proc="trace" src="line 8">
>             <input><stringConstant>Error</stringConstant></input>
>           </call>
>         </else></if>
>     </then>
>     <else>
>       <call proc="trace" src="line 12">
>         <input><stringConstant>simple_loop</stringConstant></input>
>       </call>
>     </else></if>
> </program>
> tparse.kml is:
> <project><!-- CACHE ID d263322d-8468-4df4-a357-e6aa9c628977 -->
>   <import file="sys.xml"/>
>   <import file="scheduler.xml"/>
>   <import file="rlog.xml"/>
>   <import file="vdl.k"/>
>   <global name="swift#string#17004">
>     <vdl:new type="string" value="Error" />
>   </global>
>   <global name="swift#string#17003">
>     <vdl:new type="string" value="sweep" />
>   </global>
>   <global name="swift#string#17005">
>     <vdl:new type="string" value="simple_loop" />
>   </global>
>   <global name="swift#string#17001">
>     <vdl:new type="string" value="bar" />
>   </global>
>   <global name="swift#string#17000">
>     <vdl:new type="string" value="foo" />
>   </global>
>   <global name="swift#string#17002">
>     <vdl:new type="string" value="" />
>   </global>
>   <set name="st">
>     <vdl:new type="string" dbgname="st" waitfor="88000">
>       <vdl:mapping descriptor="concurrent_mapper">
>         <vdl:parameter
> name="prefix">st-f2f01a13-f36f-458b-8cd9-2b8a8ee80c95</vdl:parameter>
>       </vdl:mapping>
>     </vdl:new>
>   </set>
>   <set name="tu">
>     <vdl:new type="string" dbgname="tu" waitfor="88001">
>         <vdl:parameter
> name="prefix">tu-91daec5d-486a-421f-8cac-58469d72f0ba</vdl:parameter>
>       </vdl:mapping>
>     </vdl:new>
>   </set>
>   <restartLog>
>         <vdl:mains>
> <!-- TODO can move into vdl:mains so karajan files are smaller -->
>                 <vdl:startprogressticker />
>                 <vdl:mainp>
>                     <parallel>
>                         <sequential>
>                              <vdl:setfieldvalue>
>                                <argument name="var">
>                                  <variable>st</variable>
>                                </argument>
>                                  <variable>swift#string#17000</variable>
>                                </argument>
>                              </vdl:setfieldvalue>
>                             <partialCloseDataset var="{st}"
> closeID="88000" />
>                         </sequential>
>                         <sequential>
>                              <vdl:setfieldvalue>
>                                  <variable>tu</variable>
>                                </argument>
>                                  <variable>swift#string#17001</variable>
>                                </argument>
>                             <partialCloseDataset var="{tu}"
> closeID="88001" />
>                         </sequential>
>                         <sequential>
>                           <if>
>                               <variable>swift#string#17002</variable>
>                           </vdlop:or></vdl:getfieldvalue>
>                             <then>
>                                 <sequential>
>                                   <if>
>                                     <vdl:getfieldvalue><vdlop:and>
>                                   </vdlop:and></vdl:getfieldvalue>
>                                     <then>
>                                         <sequential>
>                                           <trace>
>                                             <parallel>
> <variable>swift#string#17003</variable>
>                                             </parallel>
>                                           </trace>
>                                         </sequential>
>                                     </then>
>                                     <else>
>                                         <sequential>
>                                           <trace>
>                                             <parallel>
> <variable>swift#string#17004</variable>
>                                             </parallel>
>                                           </trace>
>                                         </sequential>
>                                     </else>
>                                   </if>
>                                 </sequential>
>                             </then>
>                             <else>
>                                 <sequential>
>                                   <trace>
>                                     <parallel>
> <variable>swift#string#17005</variable>
>                                     </parallel>
>                                   </trace>
>                                 </sequential>
>                             </else>
>                           </if>
>                         </sequential>
>                     </parallel>
>                 </vdl:mainp>
>                 <vdl:stopprogressticker />
>         </vdl:mains>
>   </restartLog>
> </project>
> sur$
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
