[Swift-devel] problems with external dependencies
Michael Wilde wilde at mcs.anl.gov
Sun Mar 22 19:38:31 CDT 2009
I got the example from my previous email working using this technique
(passing the external var to trace). But a script that simulates more
closely what I really need to do is still eluding me.
In the real code, I need to wait till a set of nested procedures that
involve nested foreach and iterate statements complete. So Im trying
create a simple simulation of the needed synchronization with the
following script:
type file;
app (file o) echo (int i) { echo i stdout=@o; }
(file r[]) generate() {
   int j[] = [0:10];
   foreach i in j {
     r[i] = echo(i*i);
(external w) wait(file dir[]) {
   trace("in wait: dir",dir);
app (file o) ls (string dir, external w) { ls "-l" dir stdout=@o; }
file datadir[]<simple_mapper;prefix="datadir/">;
datadir = generate();
external w1 = wait(datadir);
trace( "generate done", w1);
file out <"ls.out">;
out = ls("/home/wilde/oops/swift/datadir/", w1);
In this script the proc "generate()" simulates the production of the
data directory. I want the proc "ls" which simulates the processing of
the data directory, to wait until the directory is produced. As the
directory has too many files to pass to "ls" as an array, I pass a
string with the dir's path to ls, and want external vars to cause it to
wait till the directory is complete.
But in the case above, returning the dataset (file array) "datadir" from
generate() does not wait for the array to be "closed". Nor does passing
it to wait(), nor does passing it by name to trace().  The script gives:
Swift svn swift-r2724 (swift modified locally) cog-r2333
RunID: 20090322-1922-o4ibjxac
Progress:
SwiftScript trace: in wait: dir,
org.griphyn.vdl.karajan.FuturePairIterator at 1e671e67
SwiftScript trace: generate done, null
Progress:  Selecting site:8 Active:1 Stage out:1 Failed:1 Finished
successfully:1
Progress:  Selecting site:4 Active:1 Stage out:1 Failed:1 Finished
successfully:5
Progress:  Active:1 Stage out:1 Failed:1 Finished successfully:9
Final status:  Failed:1 Finished successfully:11
The following errors have occurred:
1. Application "ls" failed (Exit code 2)
         Arguments: "-l, /home/wilde/oops/swift/datadir/"
         Host: localhost
         Directory: ex5-20090322-1922-o4ibjxac/jobs/l/ls-ljbsob8j
         STDERR: /bin/ls: /home/wilde/oops/swift/datadir/: No such file
or directory
         STDOUT:
It seems there's only 2 kinds of constructs or behaviors that can give
me this behavior, neither of which I can find a way to cause:
- something that waits for the whole array to get its values
- something that waits for an entire array of externals to all be set
This note in the users guide suggests a possible way to do what I need:
"Statements which deal with the array as a whole will often wait for the
array to be closed before executing (thus, a closed array is the
equivalent of a non-array type being assigned). However, a foreach
statement will apply its body to elements of an array as they become
known. It will not wait until the array is closed.
What statement can I use to "wait for the array to be closed before
executing"?
On 3/22/09 4:47 PM, Ben Clifford wrote:
> As far as I can tell from a brief poke around, this is what is happening
> for you:
> Compound procedures do not themselves wait for their input parameters
> to all be ready to use. instead, they start trying to run all component
> pieces.
> If some data necessary for some component piece is not ready yet, that
> component piece will wait, so the compound procedure doesn't need to (and
> indeed shouldn't, because that reduces potential parallelism in some
> cases)
> You say this:
> analyseDatabase(external i) {
>   trace("i am analyseDatabase");
> The trace call does not have any need to wait for i to be ready. So it
> doesn't wait for i to be ready.
> If you say this:
>   trace("i am analyseDatabase", i);
> then the trace call must wait for i to be ready (and fortuitously in the
> present implementation doesn't explode even though i cannot be
> meaningfully traced).
> With that change, you'll see the behaviour you want.
