[Swift-devel] problems with external dependencies
Michael Wilde wilde at mcs.anl.gov
Sun Mar 22 16:28:12 CDT 2009
Im trying to adapt the example of external dependencies in the user
guide to enable me to wait for a procedure that does lot of parallel
work to complete, and then analyze its results.
Im trying this approach, instead of ordinary dependencies, because the
list of datasets produced in the parallel operations exceeds the command
line length limits of wrapper.sh.
So Im trying to use externals to indicate that the parallel work has
completed, then call a local analysis script with just one item from the
parallel outputs, and this script will then locate all the other outputs
with similar names by perusing a local directory passed as a string.
(theres a few more elegant variants on this, but this simple hack will
suffice for the current need).
Problem is that in the following test example to see if this will work,
the script does not seem to wait for the echo app invocations to
complete before running the final trace() function:
type file;
app (file o) echo (int i) { echo i stdout=@o; }
(external o) populateDatabase() {
   trace("I am populateDatabase");
   int j[] = [0:9];
   file r[];
   foreach i in j {
     r[i] = echo(i);
analyseDatabase(external i) {
   trace("i am analyseDatabase");
external database;
database = populateDatabase();
analyseDatabase(database);
Instead, I get:
Swift svn swift-r2724 (swift modified locally) cog-r2333
RunID: 20090322-1553-ltauz86a
Progress:
SwiftScript trace: i am analyseDatabase
SwiftScript trace: I am populateDatabase
Progress:  Selecting site:7 Stage in:1 Finished successfully:2
Progress:  Selecting site:2 Stage in:1 Active:1 Finished successfully:6
Final status:  Finished successfully:10
sur$
while I was expecting:
sur$
Ive been trying the same with an array of externals, to no avail (yet).
Can you offer any guidance on how to do this, or whether its possible
with the current implementation of external?
