[Swift-devel] RE: User script gets null pointer exception
    Yue, Chen - BMD
    yuechen at bsd.uchicago.edu
    Thu Mar 19 10:05:30 CDT 2009
Hi Michael,
I used swift version 0.8. I was able to run the same swift script last week, but I don't know why I cannot run it now. Yesterday, I was trying to set up sites.xml and tc.data for NCSA and SDSC clusters, but it didn't run. So I removed those configurations and just used all the original files to see if I can still run swift. That's when I ran into errors. The sites.xml and tc.data were in the /home/yuechen/swift-0.8/etc/. PTMap run by itself seems normal. To test PTMap, I use the following command in PTMap directory at /home/yuechen/PTMap/:
$ ./PTMap BSASolution.mzXML fasta172 inputs.txt parameters.txt
Thank you very much for help.
Chen, Yue
Sent: Thu 3/19/2009 9:22 AM
To: swift-devel
Cc: Yue, Chen - BMD; Zhao Zhang
Subject: User script gets null pointer exception
Yue, I should have clarified: this is a Swift bug.
Its perhaps caused by some error in your program, but Swift should never
get a null pointer exception.
Ben, Mihael - The log is in:
/home/yuechen/PTMapZhao/PTMap/PTMap-20090310-1746-zszi94b6.log
The error seems to be related to some boundary condition on the array
"texts" which maps Yue's 375 fasta files, fast01 .. fasta375
This message is in the log:
2009-03-10 17:46:36,188-0500 INFO  AbstractDataNode Found data
org.griphyn.vdl.mapping.RootDataNode identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20090310-1746-f12dnzdd:720000000382
type Inputfile with no value at dataset=parameter (closed).$
2009-03-10 17:46:36,188-0500 INFO  New NEW
id=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090310-1746-f12dnzdd:720000000382
2009-03-10 17:46:36,190-0500 DEBUG VDL2ExecutionContext Getting value
for array texts.$[]/375 which is not permitted.
Getting value for array texts.$[]/375 which is not permitted.
         vdl:getfieldvalue @ PTMap.kml, line: 124
         sys:parallelfor @ PTMap.kml, line: 124
         sys:sequential @ PTMap.kml, line: 123
         doall @ PTMap.kml, line: 170
         sys:sequential @ PTMap.kml, line: 169
         vdl:mainp @ PTMap.kml, line: 168
         mainp @ vdl.k, line: 165
         vdl:mains @ PTMap.kml, line: 166
         rlog:restartlog @ PTMap.kml, line: 164
         kernel:project @ PTMap.kml, line: 2
Caused by: java.lang.RuntimeException: Getting value for array
         at
org.griphyn.vdl.karajan.lib.GetFieldValue.function(GetFieldValue.java:53)
         at
org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:67)
         at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
         at
org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:335)
         at
org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
-------- Original Message --------
Subject: Re: [Swift-user] swift execution problem
Date: Thu, 19 Mar 2009 08:27:02 -0500
To: Yue, Chen - BMD <yuechen at bsd.uchicago.edu>
CC: swift-user at ci.uchicago.edu
<AD1FA15416EEBC49A0FE4F8B0C8AD7C5158C28 at ADM-EXCHVS04.bsdad.uchicago.edu>
Yue, what version of Swift are you using?
Please send the first few lines of your output file, where it says
something like:
Swift svn swift-r2701 cog-r2332
RunID: 20090319-0820-19zttiq9
(in fact please send the whole output file, stdout/err)
Ive tried to run your code in a near-identical test and I cant reproduce
the failure. Ive tried with both swift0.8 and the latest svn rev, and
both seem to work.
Also please can you post the pathname of the directory in which you are
testing (I assume you are running this on a CI machine?) so that I can
look at your logfile? And make it publicly accessible?
- Mike
On 3/18/09 6:32 PM, Yue, Chen - BMD wrote:
> Hi,
> I'm new to Swift programming. I was able to run a swift script before,
> but I couldn't run it now. I'm wondering if someone can help me figure
> out why. The swift script, sites.xml, tc.data, and all the error
> messages are copied in this email. Thank you!
> Regards,
> Chen, Yue
> Swift script
> type Fasta {}
> type PTMapOut {}
> type Solution {}
> type Inputfile {}
> app (PTMapOut ofile) PTMap (Solution sfile, Fasta fastafile, Inputfile
> input, Inputfile parameter)
>    PTMap  @filename(sfile) @filename(fastafile) @filename(input)
> @filename(parameter) stdout=@filename(ofile
> <mailto:stdout=@filename(ofile>);
> Fasta texts[] <filesys_mapper;prefix="fasta">;
> doall(Fasta texts[])
>   Solution sfile <"BSASolution.mzXML">;
>   Inputfile input <"inputs.txt">;
>   Inputfile parameter <"parameters.txt">;
>   foreach p in texts {
>     PTMapOut r <regexp_mapper;
>              source=@p <mailto:source=@p>,
>              match="fasta(.*)",
>              transform="\\1.out <file://\\1.out <file://1.out/> >"
>    r = PTMap(sfile, p, input, parameter);
> // Main
> doall(texts);
> sites.xml
> <pool handle="localhost">
>   <gridftp  url="local://localhost" />
>   <execution provider="local" />
>   <workdirectory >/var/tmp</workdirectory>
>   <profile namespace="karajan" key="jobThrottle">0</profile>
> </pool>
> tc.data
> localhost       echo            /bin/echo       INSTALLED
> INTEL32::LINUX  null
> localhost       cat             /bin/cat        INSTALLED
> INTEL32::LINUX  null
> localhost       ls              /bin/ls         INSTALLED
> INTEL32::LINUX  null
> localhost       grep            /bin/grep       INSTALLED
> INTEL32::LINUX  null
> localhost       sort            /bin/sort       INSTALLED
> INTEL32::LINUX  null
> localhost       paste           /bin/paste      INSTALLED
> INTEL32::LINUX  null
> localhost       PTMap   /home/yuechen/PTMap/PTMap       INSTALLED
> INTEL32::LINUX  null
> Error messages
> [yuechen at communicado PTMap]$ swift PTMap.swift
> Execution failed:
>         java.lang.NullPointerException
>         at
> org.globus.cog.abstraction.impl.common.task.ServiceImpl.toString(ServiceImpl.java:156)
>         at java.lang.String.valueOf(String.java:2577)
>         at java.lang.StringBuffer.append(StringBuffer.java:220)
>         at
> org.globus.cog.karajan.workflow.nodes.grid.GridNode.function(GridNode.java:31)
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:173)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:299)
>         at
> org.globus.cog.karajan.workflow.nodes.ExecuteFile.notificationEvent(ExecuteFile.java:163)
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:45)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.childCompleted(UserDefinedElement.java:283)
>         at
> org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUDE.childCompleted(SequentialImplicitExecutionUDE.java:85)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.If.childCompleted(If.java:30)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:240)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:281)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:393)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
>         at
> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> This email is intended only for the use of the individual or entity to
> which it is addressed and may contain information that is privileged and
> confidential. If the reader of this email message is not the intended
> recipient, you are hereby notified that any dissemination, distribution,
> or copying of this communication is prohibited. If you have received
> this email in error, please notify the sender and destroy/delete all
> copies of the transmittal. Thank you.
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090319/b563ecd0/attachment.html>
