[Swift-devel] Re: log-processing tools
    Ben Clifford
    benc at hawaga.org.uk
    Thu Mar 19 09:24:08 CDT 2009
On Wed, 18 Mar 2009, skenny at uchicago.edu wrote:
> hi, i was trying to grab the log processing tools, but getting
> this:
> login3% svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
> svn: URL 'https://svn.ci.uchicago.edu/svn/vdl2/log-processing'
> doesn't exist
> should i look elsewhere?
Hopefully you figured this out based on what others said in this thread.
If not - the log-processing stuff is now part of the main swift build.
You should get a swift-plot-log command in the same place as the base
swift command (i.e. if you can run swift, you should also be able to run
swift-plot-log)
