[Swift-devel] testing
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Mar 18 12:38:17 CDT 2009
Also, please put in this description the requirements that we're working
under:
- node IP connectivity
- security
- central (head) node load limits
- central (head) node job time limits
   (eg managed headnodes)
- accounting info for all resources used
   (ie generates OSG accounting records)
- etc
That will help the design converge.
On 3/18/09 12:18 PM, Michael Wilde wrote:
> Mihael, please create a design note on how coaster bootstrap and
> communication works, and use that as the basis for getting agreement on
> the approach and the range of options needed, and for getting input.
> That design description probably exists in various material you have,
> and can be brief.
> On 3/18/09 10:40 AM, Mihael Hategan wrote:
>> On Wed, 2009-03-18 at 15:20 +0000, Ben Clifford wrote:
>>> On Wed, 18 Mar 2009, Mihael Hategan wrote:
>>>> Ben, the point is to run with one of the scheduler providers, not
>>>> gram2.
>>> That is also bad for OSG, as far as I can tell because it screws up
>>> accounting which is done in GRAM, not in the LRM.
>>> Pretty much what I'm asserting is that both the head job and the
>>> worker jobs need to be run through Conodr-G/gridmanager/gram2 (in my
>>> understanding of what OSG requires).
>> Ok. Back to the drawing board.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
