[Swift-devel] null pointer exception from nested loops
Ian Foster
foster at anl.gov
Tue Mar 17 17:22:07 CDT 2009
I wasn't sure if this ran without Swift--with just Falkon
On Mar 17, 2009, at 5:05 PM, Michael Wilde wrote:
> Not quite sure what you're asking, Ian.
> The latest tests have been on BGP w/ Falkon.
> Earlier tests were on other clusters.
> The scripts has grown in last week or so, on BGP, and grew some more
> today to explore some new science code algorithm questions.
> Its not yet running at full desired scale on the BGP; we are now
> scaling up carefully so as not to impact other users.
> This is a test case for the "cio" work as well.
> - Mike
> On 3/17/09 4:26 PM, Ian Foster wrote:
>> Just curious, is the whole thing working with just Falkon?
>> On Mar 17, 2009, at 4:25 PM, Michael Wilde wrote:
>>> The log contains this just before the NPE, including the
>>> suspicious message: WARN FlowNode Ex098:
>>> Thats giving me a clue as to the offending statements.
>>> 2009-03-17 16:20:34,723-0500 INFO AbstractDataNode Adding handle
>>> listener "F/org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu
>>> ,2008:swift:dataset:20090\
>>> 317-1620-e1n1bz3g:720000000071 type SecSeq with no value at
>>> dataset=secseq path=[0] (not closed)" to
>>> "org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu
>>> 2008:swift:dataset:20090317-1620-e1n1bz3g:720000000071 type SecSeq
>>> with no value at dataset=secseq path=[0] (not closed)"
>>> 2009-03-17 16:20:34,724-0500 INFO AbstractDataNode closed
>>> org.griphyn.vdl.mapping.RootDataNode identifier tag:benc at ci.uchicago.edu
>>> ,2008:swift:dataset:20090317-1620-e1n1bz\
>>> 3g:720000000092 type string value=s/@DIT@/10/ dataset=unnamed
>>> SwiftScript value (closed)
>>> 2009-03-17 16:20:34,724-0500 INFO AbstractDataNode ROOTPATH
>>> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-
>>> e1n1bz3g:720000000092 path=$
>>> 2009-03-17 16:20:34,724-0500 INFO AbstractDataNode VALUE
>>> e1n1bz3g:720000000092 VALUE=s/@DIT@/10/
>>> 2009-03-17 16:20:34,725-0500 INFO AbstractDataNode closed
>>> 3g:720000000093 type string value=s/@TUI@/1/ dataset=unnamed
>>> 2009-03-17 16:20:34,725-0500 INFO AbstractDataNode ROOTPATH
>>> e1n1bz3g:720000000093 path=$
>>> 2009-03-17 16:20:34,725-0500 INFO AbstractDataNode VALUE
>>> e1n1bz3g:720000000093 VALUE=s/@TUI@/1/
>>> 2009-03-17 16:20:34,726-0500 INFO AbstractDataNode closed
>>> 3g:720000000094 type string value=params.tloop dataset=unnamed
>>> 2009-03-17 16:20:34,726-0500 INFO AbstractDataNode ROOTPATH
>>> e1n1bz3g:720000000094 path=$
>>> 2009-03-17 16:20:34,726-0500 INFO AbstractDataNode VALUE
>>> e1n1bz3g:720000000094 VALUE=params.tloop
>>> 2009-03-17 16:20:34,727-0500 WARN FlowNode Ex098
>>> java.lang.NullPointerException
>>> at
>>> org
>>> .griphyn.vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:
>>> 285)
>>> at
>>> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:
>>> 201)
>>> at
>>> 182)
>>> at
>>> org
>>> .griphyn
>>> .vdl.karajan.lib.swiftscript.FileName.function(FileName.java:19)
>>> at
>>> org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:67)
>>> On 3/17/09 4:17 PM, Michael Wilde wrote:
>>>> It seems not related to scale or Falkon.
>>>> It occurs when running on localhost (but on bgp) and when I cut
>>>> all the loops down to a single iteration.
>>>> I'm still debugging.
>>>> On 3/17/09 4:07 PM, Michael Wilde wrote:
>>>>> I just expanded my oops protein folding script to add another
>>>>> level of parameter sweep. This script is getting pretty complex
>>>>> now (at least, for a swift script).
>>>>> I got the following npe on my first two tries. Im going to start
>>>>> debugging, but any clues as to the cause would be helpful.
>>>>> The outer loops are:
>>>>> main()
>>>>> string protein[] = readData(@arg("plist"));
>>>>> string startTemp[] = ["10","20"];
>>>>> string tempUpdate[] = ["1","2","3"];
>>>>> foreach p in protein {
>>>>> foreach st in startTemp {
>>>>> foreach tu in tempUpdate {
>>>>> doRoundSet(p,st,tu);
>>>>> There are two levels of inner loops further down below
>>>>> doRoundSet().
>>>>> The script, output, command line args and log are in:
>>>>> http://ww.ci.uchicago.edu/~wilde/swift3.tar.gz
>>>>> I suspect it will take a while to narrow the cause to a simpler
>>>>> test case thats easy tp reproduce without a lot of setup.
>>>>> I'll try on a vanilla swift on local execution; this is on bgp
>>>>> with Falkon.
>>>>> Thanks.
>>>>> Progress: uninitialized:1 Selecting site:2
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 7
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 2
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 8
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 0
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 5
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 9
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 1
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 6
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 3
>>>>> SwiftScript trace: T1af7, Round, 0, Sim, 4
>>>>> Ex098
>>>>> at
>>>>> org
>>>>> .griphyn
>>>>> .vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:285)
>>>>> at
>>>>> org
>>>>> 201)
>>>>> at
>>>>> org
>>>>> 182)
>>>>> at
>>>>> org
>>>>> .griphyn
>>>>> at
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes
>>>>> .AbstractSequentialWithArguments
>>>>> .childCompleted(AbstractSequentialWithArguments.java:192)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
>>>>> at
>>>>> org
>>>>> .globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:
>>>>> 332)
>>>>> at
>>>>> org
>>>>> .globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:
>>>>> 125)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:296)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:
>>>>> 51)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow.nodes.Sequential.executeChildren(Sequential.java:27)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes
>>>>> .functions
>>>>> .AbstractFunction.executeChildren(AbstractFunction.java:40)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:
>>>>> 63)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
>>>>> at
>>>>> org
>>>>> .globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:
>>>>> 278)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:
>>>>> 391)
>>>>> at
>>>>> org
>>>>> 329)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
>>>>> at
>>>>> org
>>>>> 125)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
>>>>> Execution failed:
>>>>> at
>>>>> org
>>>>> .griphyn
>>>>> at
>>>>> org
>>>>> 201)
>>>>> at
>>>>> org
>>>>> 182)
>>>>> at
>>>>> org
>>>>> .griphyn
>>>>> at
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> 332)
>>>>> at
>>>>> org
>>>>> 125)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> at
>>>>> org
>>>>> .globus
>>>>> 51)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes
>>>>> .functions
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> 63)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> 278)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> 391)
>>>>> at
>>>>> org
>>>>> 329)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> 125)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> Ex098
>>>>> at
>>>>> org
>>>>> .griphyn
>>>>> at
>>>>> org
>>>>> 201)
>>>>> at
>>>>> org
>>>>> 182)
>>>>> at
>>>>> org
>>>>> .griphyn
>>>>> at
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> 332)
>>>>> at
>>>>> org
>>>>> 125)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> at
>>>>> org
>>>>> .globus
>>>>> 51)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> .workflow
>>>>> .nodes
>>>>> .functions
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> 63)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> 278)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> 391)
>>>>> at
>>>>> org
>>>>> 329)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> .cog
>>>>> .karajan
>>>>> at
>>>>> org
>>>>> 125)
>>>>> at
>>>>> org
>>>>> .globus
>>>>> at
>>>>> org
>>>>> .globus
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090317/e12ca4de/attachment.html>
