[Swift-devel] null pointer exception from nested loops
    Ian Foster
    foster at anl.gov
    Tue Mar 17 16:26:25 CDT 2009
Just curious, is the whole thing working with just Falkon?
On Mar 17, 2009, at 4:25 PM, Michael Wilde wrote:
> The log contains this just before the NPE, including the suspicious
> message: WARN  FlowNode Ex098:
> Thats giving me a clue as to the offending statements.
> 2009-03-17 16:20:34,723-0500 INFO  AbstractDataNode Adding handle
> listener "F/org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu
> ,2008:swift:dataset:20090\
> 317-1620-e1n1bz3g:720000000071 type SecSeq with no value at
> dataset=secseq path=[0] (not closed)" to
> "org.griphyn.vdl.mapping.DataNode identifier
> tag:benc at ci.uchicago.edu,\
> 2008:swift:dataset:20090317-1620-e1n1bz3g:720000000071 type SecSeq
> with no value at dataset=secseq path=[0] (not closed)"
> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode closed
> org.griphyn.vdl.mapping.RootDataNode identifier tag:benc at ci.uchicago.edu
> ,2008:swift:dataset:20090317-1620-e1n1bz\
> 3g:720000000092 type string value=s/@DIT@/10/ dataset=unnamed
> SwiftScript value (closed)
> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode ROOTPATH
> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-
> e1n1bz3g:720000000092 path=$
> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode VALUE
> e1n1bz3g:720000000092 VALUE=s/@DIT@/10/
> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode closed
> 3g:720000000093 type string value=s/@TUI@/1/ dataset=unnamed
> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode ROOTPATH
> e1n1bz3g:720000000093 path=$
> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode VALUE
> e1n1bz3g:720000000093 VALUE=s/@TUI@/1/
> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode closed
> 3g:720000000094 type string value=params.tloop dataset=unnamed
> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode ROOTPATH
> e1n1bz3g:720000000094 path=$
> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode VALUE
> e1n1bz3g:720000000094 VALUE=params.tloop
> 2009-03-17 16:20:34,727-0500 WARN  FlowNode Ex098
> java.lang.NullPointerException
>        at
> org
> .griphyn.vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:
> 285)
>        at
> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:201)
>        at
> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:182)
>        at
> org
> .griphyn.vdl.karajan.lib.swiftscript.FileName.function(FileName.java:
> 19)
>        at
> org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:67)
> On 3/17/09 4:17 PM, Michael Wilde wrote:
>> It seems not related to scale or Falkon.
>> It occurs when running on localhost (but on bgp) and when I cut all
>> the loops down to a single iteration.
>> I'm still debugging.
>> On 3/17/09 4:07 PM, Michael Wilde wrote:
>>> I just expanded my oops protein folding script to add another
>>> level of parameter sweep. This script is getting pretty complex
>>> now (at least, for a swift script).
>>> I got the following npe on my first two tries. Im going to start
>>> debugging, but any clues as to the cause would be helpful.
>>> The outer loops are:
>>> main()
>>>  string protein[] = readData(@arg("plist"));
>>>  string startTemp[] = ["10","20"];
>>>  string tempUpdate[] = ["1","2","3"];
>>>  foreach p in protein {
>>>    foreach st in startTemp {
>>>      foreach tu in tempUpdate {
>>>        doRoundSet(p,st,tu);
>>> There are two levels of inner loops further down below doRoundSet().
>>> The script, output, command line args and log are in:
>>> http://ww.ci.uchicago.edu/~wilde/swift3.tar.gz
>>> I suspect it will take a while to narrow the cause to a simpler
>>> test case thats easy tp reproduce without a lot of setup.
>>> I'll try on a vanilla swift on local execution; this is on bgp
>>> with Falkon.
>>> Thanks.
>>> Progress:  uninitialized:1 Selecting site:2
>>> SwiftScript trace: T1af7, Round, 0, Sim, 7
>>> SwiftScript trace: T1af7, Round, 0, Sim, 2
>>> SwiftScript trace: T1af7, Round, 0, Sim, 8
>>> SwiftScript trace: T1af7, Round, 0, Sim, 0
>>> SwiftScript trace: T1af7, Round, 0, Sim, 5
>>> SwiftScript trace: T1af7, Round, 0, Sim, 9
>>> SwiftScript trace: T1af7, Round, 0, Sim, 1
>>> SwiftScript trace: T1af7, Round, 0, Sim, 6
>>> SwiftScript trace: T1af7, Round, 0, Sim, 3
>>> SwiftScript trace: T1af7, Round, 0, Sim, 4
>>> Ex098
>>>    at
>>> org
>>> 285)
>>>    at
>>> 201)
>>>    at
>>> 182)
>>>    at
>>> org
>>> .griphyn
>>> .vdl.karajan.lib.swiftscript.FileName.function(FileName.java:19)
>>>    at
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes
>>> .AbstractSequentialWithArguments
>>> .childCompleted(AbstractSequentialWithArguments.java:192)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
>>>    at
>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:
>>> 332)
>>>    at
>>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:
>>> 125)
>>>    at
>>> org
>>> .globus
>>> .cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
>>>    at
>>> org
>>> .globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:
>>> 296)
>>>    at
>>> org
>>> .globus
>>> .cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:
>>> 58)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>>>    at
>>> org
>>> .globus
>>> .cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:
>>> 27)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes
>>> .functions.AbstractFunction.executeChildren(AbstractFunction.java:
>>> 40)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>>>    at
>>> org
>>> .globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:
>>> 233)
>>>    at
>>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:
>>> 278)
>>>    at
>>> org
>>> .globus
>>> .cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
>>>    at
>>> 329)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:
>>> 227)
>>>    at
>>> 125)
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> .cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
>>> Execution failed:
>>>    at
>>> org
>>> 285)
>>>    at
>>> 201)
>>>    at
>>> 182)
>>>    at
>>> org
>>> .griphyn
>>>    at
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>>    at
>>> 332)
>>>    at
>>> 125)
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>>    at
>>> org
>>> 296)
>>>    at
>>> org
>>> .globus
>>> 58)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> .cog
>>> 27)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes
>>> 40)
>>>    at
>>> org
>>> .globus
>>> .cog
>>>    at
>>> org
>>> 233)
>>>    at
>>> 278)
>>>    at
>>> org
>>> .globus
>>>    at
>>> 329)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> 227)
>>>    at
>>> 125)
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> Ex098
>>>    at
>>> org
>>> 285)
>>>    at
>>> 201)
>>>    at
>>> 182)
>>>    at
>>> org
>>> .griphyn
>>>    at
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>>    at
>>> 332)
>>>    at
>>> 125)
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>>    at
>>> org
>>> 296)
>>>    at
>>> org
>>> .globus
>>> 58)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> .cog
>>> 27)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> .karajan
>>> .workflow
>>> .nodes
>>> 40)
>>>    at
>>> org
>>> .globus
>>> .cog
>>>    at
>>> org
>>> 233)
>>>    at
>>> 278)
>>>    at
>>> org
>>> .globus
>>>    at
>>> 329)
>>>    at
>>> org
>>> .globus
>>> .cog
>>> 227)
>>>    at
>>> 125)
>>>    at
>>> org
>>> .globus
>>>    at
>>> org
>>> .globus
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
