[Swift-devel] Quick Start Guide examples are mangled
    Ben Clifford
    benc at hawaga.org.uk
    Fri Mar  6 07:42:32 CST 2009
On Fri, 6 Mar 2009, Ben Clifford wrote:
> > I dont know when this appeared, but some of the example text in the Swift
> > Quick Start Guide at:
> > http://www.ci.uchicago.edu/swift/guides/quickstartguide.php#install
> > Is getting rendered wrong - its full of html tags and unreadable. Looks like:
> I changed a style sheet there the other day, which likely caused it. oops.
fixed in r2646:
    Change use of <programlisting> elements for console interactions into
    <screen> elements.
    <programlisting> elements undergo magic syntax highlighting under the
    swiftsh_html.xsl style sheet that the quickstart guides were switched
    to in r2614
