[Swift-devel] different host CN expectations in gram and	gridftp  server
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Mar  4 14:04:41 CST 2009
http://bugzilla.mcs.anl.gov/globus/show_bug.cgi?id=6678
Use login3.ranger.tacc.utexas.edu instead of
gatekeeper.ranger.tacc.teragrid.org if your submit host is a node on
ranger. Though I'd recommend against running swift on one of ranger's
head nodes.
On Tue, 2009-02-24 at 15:17 -0600, Mihael Hategan wrote:
> Ok. I'll look into this.
> On Tue, 2009-02-24 at 15:14 -0600, Allan Espinosa wrote:
> > I still get the same gram authentication error message:
> > Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > Cannot submit job
> > Caused by: org.globus.gram.GramException: Data transfer to the server
> > failed [Caused by: Authentication failed [Caused by: Operation
> > unauthorized (Mechanism level: [JGLOBUS-56] Authorization failed.
> > Expected "/CN=host/129.114.50.163" target but received
> > "/C=US/O=UTAustin/OU=TACC/CN=login3.ranger.tacc.utexas.edu")]]
> > 2009-02-24 15:12:07,215-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> > jobid=hostname-8tx7p37j - Application exception: Cannot submit job
> > This is using both the fork and sge job manager via gram2-only
> > -aallan
> > On Mon, Feb 23, 2009 at 10:58 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> > > If you use gram2 instead of coasters+gram2, what happens?
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
