[Swift-devel] hprof profiling of coaster services
Michael Wilde
wilde at mcs.anl.gov
Fri Jun 26 07:46:04 CDT 2009
Allan, can you try this, as part of the other testing that I suggested
in the prior message on this thread? I.e, re-run the suggested coaster
overhead measurement tests without logging, but only if the tests *with*
logging indicate high overhead?
It would be interesting to also compare logfile sizes in both cases.
- Mike
On 6/24/09 6:30 PM, Mihael Hategan wrote:
> Try the following:
> In the source tree, edit
> cog/modules/provider-coaster/resources/log4j.properties and change the
> INFO categories to WARN.
> Then re-compile and see if the usage is still high.
> On Tue, 2009-06-23 at 17:11 -0500, Allan Espinosa wrote:
>> ok this looks like a good replicable case.
>> the workflow is 2000 invocations of touch using 066-many.swift
>> run04.tar.gz (logs and a "top -b" dump for the coaster service). cpu
>> utilization averages to 99-100% . i ran this for five trials and got
>> the same results.
>> run05.tar.gz - same run with profiling information. in java.hprof.bin
>> 2009/6/19 Mihael Hategan <hategan at mcs.anl.gov>:
>>> On Fri, 2009-06-19 at 18:30 -0500, Allan Espinosa wrote:
>>>> here's a script recording without profiling of top:
>>>> http://www.ci.uchicago.edu/~aespinosa/top_vanilla.gz
>>>> it still consumes some cpu. but does not spike to 200% utilization.
>>> Right, 10% != 200%.
>>> Now, as you're probably already guessing, I would need:
>>> 1. a situation (workflow/site/etc.) in which the usage does go crazy
>>> without the profiler (as in what triggered you getting kicked off
>>> ranger); repeatable
>>> 2. a profiler dump of a run in such a situation
>>> Btw, the ranger issue, where was swift running?
>> on communicado.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
