[Swift-devel] gparallelizer DataflowConcurrency
Ben Clifford
benc at hawaga.org.uk
Sun Jun 21 11:28:28 CDT 2009
One thing that is apparent here that Swift doesn't have (and I think is
better for Swift ot not have) is the distinction between immediate
variables (that have a value) and future values (represented by
DataFlowVariable objects) - to get access to those future values you need
to dereference their value with ~ (which returns the relevant immediate
value or if that immediate value is not available, suspends the present
thread of execution until such time as that immediate value is available).
The distinction between immediate and future values in the language is a
little awkward - for example, instead of z=x+y, you must write z << ~x +
~y to interface the imediate value desiring + operator with the future
value variables z, x and y using ~ to dereference and << instead of = to
assign. This exposure of the interfacing between immediate and future
worlds seems a bit awkward.
Swift used to distinguish some between immediate and future values in its
implementation (although not really in the syntax); I think its good that
we got rid of that distinction and have only future values for everything.
It would of course be possible to write some kind of + operator that did
the referncing and dereferencing, but this would not in general happen
automatically for every possible function and operator.
This is the same trouble as using pointers in C with the * operator to
access the value of that pointer, or using weak references in Java using
.get() syntax to access the value of the weak reference - its nothing
particularly specific to programming using futures. But it looks ugly and
awkward in all of them...
