[Swift-devel] Re: [CI Ticketing System #1074] How to set .soft and env to run condor on TeraPort? (fwd)
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jun 19 11:24:39 CDT 2009
On 6/19/09 11:18 AM, Ben Clifford wrote:
> If its being exposed to users, this should be fixed in softenv, not worked
> around with sourcing setup shell scripts.
Indeed, yes. Maybe prelim info that works, can be posted, till then, if
this takes much longer.
> On Fri, 19 Jun 2009, Mike Wilde wrote:
>> Zhao, when the best way for regular users to do this is determined
>> (sounds like its close) please put instructions for how to do it on:
>> http://www.ci.uchicago.edu/wiki/bin/view/SWFT
>> as page SwiftQuickStartForCondorG
>> (including all the Swift config issues, eg sites.xml, etc)
>> Thanks,
>> Mike
>> ps. I think you have a few other pages that should go there, eg, BGP,
>> Ranger/Coasters, etc.
>> How to run on your own local PBS cluster
>> On 6/19/09 11:07 AM, Ben Clifford wrote:
>>> ci support got removed from this thread but I believe this is relevant.
>>> Zhao also reports the same way of getting it working, in another
>>> non-ci-support message.
>>> ---------- Forwarded message ----------
>>> Date: Fri, 19 Jun 2009 16:00:13 +0000 (GMT)
>>> From: Ben Clifford <benc at hawaga.org.uk>
>>> To: Glen Hocky <support at ci.uchicago.edu>
>>> Cc: wilde at mcs.anl.gov, sthapa at ci.uchicago.edu, swift-devel at ci.uchicago.edu,
>>>     zhaozhang at uchicago.edu, papka at ci.uchicago.edu
>>> Subject: Re: [CI Ticketing System #1074] How to set .soft and env to run  condor
>>>      on TeraPort?
>>> my experience on tp-osg is that sourcing /opt/osg/setup.sh makes condor
>>> work. this suggests perhaps that in a working environment, condor should
>>> be coming from that OSG stack and not from a specific condor softenv key.
