[Swift-devel] [CI Ticketing System #1074] How to set .soft and env to run condor on TeraPort?
Ti Leggett
support at ci.uchicago.edu
Fri Jun 19 11:21:21 CDT 2009
If this is the case, then it sounds like @osg needs to be used on the Teraport
instead of @globus-4. Can you try that and see if that helps?
On Fri Jun 19 11:00:27 2009, benc at hawaga.org.uk wrote:
> my experience on tp-osg is that sourcing /opt/osg/setup.sh makes condor
> work. this suggests perhaps that in a working environment, condor should
> be coming from that OSG stack and not from a specific condor softenv key.
