[Swift-devel] Re: [CI Ticketing System #1074] How to set .soft and env to run condor on TeraPort? (fwd)
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jun 19 11:17:47 CDT 2009
If its being exposed to users, this should be fixed in softenv, not worked
around with sourcing setup shell scripts.
On Fri, 19 Jun 2009, Mike Wilde wrote:
> Zhao, when the best way for regular users to do this is determined
> (sounds like its close) please put instructions for how to do it on:
> http://www.ci.uchicago.edu/wiki/bin/view/SWFT
> as page SwiftQuickStartForCondorG
> (including all the Swift config issues, eg sites.xml, etc)
> Thanks,
> Mike
> ps. I think you have a few other pages that should go there, eg, BGP,
> Ranger/Coasters, etc.
> How to run on your own local PBS cluster
> On 6/19/09 11:07 AM, Ben Clifford wrote:
> > ci support got removed from this thread but I believe this is relevant.
> > Zhao also reports the same way of getting it working, in another
> > non-ci-support message.
> > ---------- Forwarded message ----------
> > Date: Fri, 19 Jun 2009 16:00:13 +0000 (GMT)
> > From: Ben Clifford <benc at hawaga.org.uk>
> > To: Glen Hocky <support at ci.uchicago.edu>
> > Cc: wilde at mcs.anl.gov, sthapa at ci.uchicago.edu, swift-devel at ci.uchicago.edu,
> >     zhaozhang at uchicago.edu, papka at ci.uchicago.edu
> > Subject: Re: [CI Ticketing System #1074] How to set .soft and env to run  condor
> >      on TeraPort?
> > my experience on tp-osg is that sourcing /opt/osg/setup.sh makes condor
> > work. this suggests perhaps that in a working environment, condor should
> > be coming from that OSG stack and not from a specific condor softenv key.
