[Swift-devel] Re: swift testing of gram5 on teraport
Michael Wilde wilde at mcs.anl.gov
Fri Jun 19 11:08:02 CDT 2009
Is what we're looking to see here the ability to run Swift with a full
or wide throttle to Gram5, directly, without Condor-G, and the ability
to have (a) lots of jobs in the queue and (b) many more jobs running at
once, while watching the gatekeepr host for CPU stress and memory pressure?
Where say (a) is a few thousand jobs and (b) is the full cluster busy?
I wonder if we can get a full-system reservation on TeraPort to test this?
We're also testing Swift via Condor-G at the moment on UNL's new cluster
"Firefly" which has 6000 cores of which 3000 are accessible to OSG. As
its a new and lightly loaded cluster, perhaps Brian Bockelman would be
willing to test GRAM5 on it? (its a PBS cluster)
So, now that I think about, as long as there's a GRAM5 gatekeeper we can
use, since it should Just Work, Im sure we can give it some informal
usage as soon as its available.
Stu, do you have plans for testing beyon Teraport on larger clusters?
I wonder, maybe we could test it in AWS at large scales too on a Nimbus
workspace?
- Mike
On 6/19/09 10:58 AM, Ben Clifford wrote:
> On Fri, 19 Jun 2009, Michael Wilde wrote:
>> In parallel, we should discuss on the list what ifany Swift changes are needed
>> to use it. It dont have my head around the issue at the moment. Where can we
>> read the specs of how it affects the user?
> Theoretically it will Just Work with the GRAM2 provider. Evidence thus far
> suggests this might be true (for example, apparently the gram2 cog stuff
> can submit to gram5 ok) but there hasn't been any swift-level testing to
> see how it all fits together.
