[Swift-devel] Re: [CI Ticketing System #1074] How to set .soft and	env to run condor on TeraPort?
    Glen Hocky
    hockyg at uchicago.edu
    Fri Jun 19 11:05:52 CDT 2009
That did it for me! Thanks Zhao
On Fri, Jun 19, 2009 at 11:00 AM, Zhao Zhang <zhaozhang at uchicago.edu> wrote:
> Here is my .soft
> [zzhang at tp-grid1 ~]$ cat .soft
> # This is your SoftEnv configuration run control file.
> #   It is used to tell SoftEnv how to customize your environment by
> #   setting up variables such as PATH and MANPATH.  To learn more
> #   about this file, do a "man softenv".
> +java-sun
> +osg-client
> +maui
> +torque
> @python-2.5
> @osg
> @default
> @globus-4
> And the source file is
> source /opt/osg/setup.sh
> zhao
> Glen Hocky wrote:
>> This did update my condor and globus locations, but did not fix the
>> problem. Hopefully Zhao can tell me what to do next
>> [hockyg at tp-grid1 swift]$ which condor_q
>> /soft/condor-7.0.5-r1/bin/condor_q
>> [hockyg at tp-grid1 swift]$ condor_q
>> Neither the environment variable CONDOR_CONFIG,
>> /etc/condor/, nor ~condor/ contain a condor_config source.
>> Either set CONDOR_CONFIG to point to a valid config source,
>> or put a "condor_config" file in /etc/condor or ~condor/
>> Exiting.
>> On Fri, Jun 19, 2009 at 8:49 AM, Ti Leggett <support at ci.uchicago.edu<mailto:
>> support at ci.uchicago.edu>> wrote:
>>    There were some misconfigurations in the @globus-4 macro for
>>    rhel-5 and condor
>>    that I've just fixed. Can you set your ~/.soft to look like below
>>    and then run
>>    resoft:
>>    @globus-4
>>    @default
>>    You should be using /soft/condor-7.0.5-r1 and
>>    /soft/globus-4.2.1-r2 after that.
>>    Let me know if that works for you, or if anything changes.
>>    On Thu Jun 18 16:44:15 2009, wilde at mcs.anl.gov
>>    <mailto:wilde at mcs.anl.gov> wrote:
>>    > Hi,
>>    > Swift users need to run the condor-g client in order to send jobs to
>>    > OSG
>>    > sites from a Swift script.
>>    > Can you tell us how to set .soft and env so that condor_submit to
>>    > "grid"
>>    > universe works?
>>    > We've had all sorts of problems in getting this to work well:
>>    > - the version of condor client code on communicado is too new to run
>>    > with Swift.
>>    > - On teraport, it seems difficult to get the right settings of .soft
>>    > entries and setup.sh scripts to work corrcetly together
>>    > - I still dont know if what worked for Zhao on tp-osg a month ago
>>    > still
>>    > works. It seems not to, and I cant tell if its because of a
>>    change in
>>    > .soft or env settings, or some other software issue
>>    > - We would like to run from Teraport compute nodes with qsub -I, and
>>    > hope that whatever we determine to be the right settings for login
>>    > nodes
>>    > work on interactive compute nodes as well.
>>    > - It would be good *not* to run on tp-osg.
>>    > Suchandra, Ti, or Greg, can you help us sort out how to set things
>>    > correctly?
>>    > Tanks,
>>    > Mike
>>    > -------- Original Message --------
>>    > Subject: Re: [Swift-devel] Cant run condor-g on TeraPort
>>    > Date: Thu, 18 Jun 2009 19:31:26 +0000 (GMT)
>>    > From: Ben Clifford <benc at hawaga.org.uk <mailto:benc at hawaga.org.uk>>
>>    > To: Michael Wilde <wilde at mcs.anl.gov <mailto:wilde at mcs.anl.gov>>
>>    > CC: swift-devel <swift-devel at ci.uchicago.edu
>>    <mailto:swift-devel at ci.uchicago.edu>>
>>    > References: <4A3A93E2.2080805 at mcs.anl.gov
>>    <mailto:4A3A93E2.2080805 at mcs.anl.gov>>
>>    > condor_q works for me on tp-osg if I source /opt/osg/setenv.sh
>>    rather
>>    > than
>>    > use softenv. it doesn't work for me if I use @osg in softenv,
>>    with the
>>    > error you report.
>>    > On Thu, 18 Jun 2009, Michael Wilde wrote:
>>    > > As far as I can tell, the condor client code is broken on
>>    TeraPort.
>>    > > Ive tried this on tp-login and tp-osg; I am using +osg-client and
>>    > @osg in my
>>    > > .soft. I source $VDT_LOCATION/setup.sh
>>    > > Zhao, Glen, can you cross-check and see if you are now seeing the
>>    > same thing?
>>    > > My suspicion is that the condor client config broke in the last
>>    > month, through
>>    > > OSG changes, CI Support work, etc etc.
>>    > > - Mike
>>    > > I get this from condor_q:
>>    > > tp$ condor_q
>>    > > Error:
>>    > > Extra Info: You probably saw this error because the
>>    condor_schedd is
>>    > not
>>    > > running on the machine you are trying to query. If the
>>    condor_schedd
>>    > is not
>>    > > running, the Condor system will not be able to find an address and
>>    > port to
>>    > > connect to and satisfy this request. Please make sure the Condor
>>    > daemons are
>>    > > running and try again.
>>    > > Extra Info: If the condor_schedd is running on the machine you are
>>    > trying to
>>    > > query and you still see the error, the most likely cause is
>>    that you
>>    > have
>>    > > setup a personal Condor, you have not defined SCHEDD_NAME in your
>>    > > condor_config file, and something is wrong with your
>>    > SCHEDD_ADDRESS_FILE
>>    > > setting. You must define either or both of those settings in your
>>    > config
>>    > > file, or you must use the -name option to condor_q. Please see the
>>    > Condor
>>    > > manual for details on SCHEDD_NAME and SCHEDD_ADDRESS_FILE.
>>    > > tp$
>>    > > and this from swift:
>>    > > tp-grid1$ swift -tc.file tc.data -sites.file sites.condorg.xml
>>    > cat.swift
>>    > > Swift svn swift-r2890 cog-r2392
>>    > > RunID: 20090618-1404-mo0thjj4
>>    > > Progress:
>>    > > Progress: Stage in:1
>>    > > Progress: Submitted:1
>>    > > Failed to transfer wrapper log from cat-20090618-1404-
>>    > mo0thjj4/info/h on
>>    > > firefly
>>    > > Progress: Failed:1
>>    > > Execution failed:
>>    > > Exception in cat:
>>    > > Arguments: [data.txt]
>>    > > Host: firefly
>>    > > Directory: cat-20090618-1404-mo0thjj4/jobs/h/cat-hv5s3gcj
>>    > > stderr.txt:
>>    > > stdout.txt:
>>    > > Caused by:
>>    > > Cannot submit job: Could not submit job (condor_submit reported an
>>    > > exit code of 1). no error output
>>    > > tp-grid1$ ls
>>    > > Using this sites file:
>>    > > <config>
>>    > > <pool handle="firefly" >
>>    > > <gridftp url="gsiftp://ff-grid.unl.edu
>>    <http://ff-grid.unl.edu>" />
>>    > > <execution provider="condor" />
>>    > > <profile namespace="globus" key="jobType">grid</profile>
>>    > > <profile namespace="globus" key="gridResource">gt2
>>    > > ff-grid.unl.edu/jobmanager-pbs
>>    <http://ff-grid.unl.edu/jobmanager-pbs></profile>
>>    > > <workdirectory
>>    > >/panfs/panasas/CMS/data/oops/wilde/swiftwork</workdirectory>
>>    > > </pool>
>>    > > </config>
>>    > > _______________________________________________
>>    > > Swift-devel mailing list
>>    > > Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>>    > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090619/4e3d4ba1/attachment.html>
