[Swift-devel] Re: [CI Ticketing System #1074] How to set .soft and	env to run condor on TeraPort?
    Glen Hocky
    hockyg at uchicago.edu
    Fri Jun 19 10:56:50 CDT 2009
This did update my condor and globus locations, but did not fix the problem.
Hopefully Zhao can tell me what to do next
[hockyg at tp-grid1 swift]$ which condor_q
/soft/condor-7.0.5-r1/bin/condor_q
[hockyg at tp-grid1 swift]$ condor_q
Neither the environment variable CONDOR_CONFIG,
/etc/condor/, nor ~condor/ contain a condor_config source.
Either set CONDOR_CONFIG to point to a valid config source,
or put a "condor_config" file in /etc/condor or ~condor/
Exiting.
On Fri, Jun 19, 2009 at 8:49 AM, Ti Leggett <support at ci.uchicago.edu> wrote:
> There were some misconfigurations in the @globus-4 macro for rhel-5 and
> condor
> that I've just fixed. Can you set your ~/.soft to look like below and then
> run
> resoft:
> @globus-4
> @default
> You should be using /soft/condor-7.0.5-r1 and /soft/globus-4.2.1-r2 after
> that.
> Let me know if that works for you, or if anything changes.
> On Thu Jun 18 16:44:15 2009, wilde at mcs.anl.gov wrote:
> > Hi,
> > Swift users need to run the condor-g client in order to send jobs to
> > OSG
> > sites from a Swift script.
> > Can you tell us how to set .soft and env so that condor_submit to
> > "grid"
> > universe works?
> > We've had all sorts of problems in getting this to work well:
> > - the version of condor client code on communicado is too new to run
> > with Swift.
> > - On teraport, it seems difficult to get the right settings of .soft
> > entries and setup.sh scripts to work corrcetly together
> > - I still dont know if what worked for Zhao on tp-osg a month ago
> > still
> > works. It seems not to, and I cant tell if its because of a change in
> > .soft or env settings, or some other software issue
> > - We would like to run from Teraport compute nodes with qsub -I, and
> > hope that whatever we determine to be the right settings for login
> > nodes
> > work on interactive compute nodes as well.
> > - It would be good *not* to run on tp-osg.
> > Suchandra, Ti, or Greg, can you help us sort out how to set things
> > correctly?
> > Tanks,
> > Mike
> > -------- Original Message --------
> > Subject: Re: [Swift-devel] Cant run condor-g on TeraPort
> > Date: Thu, 18 Jun 2009 19:31:26 +0000 (GMT)
> > From: Ben Clifford <benc at hawaga.org.uk>
> > To: Michael Wilde <wilde at mcs.anl.gov>
> > CC: swift-devel <swift-devel at ci.uchicago.edu>
> > References: <4A3A93E2.2080805 at mcs.anl.gov>
> > condor_q works for me on tp-osg if I source /opt/osg/setenv.sh rather
> > than
> > use softenv. it doesn't work for me if I use @osg in softenv, with the
> > error you report.
> > On Thu, 18 Jun 2009, Michael Wilde wrote:
> > > As far as I can tell, the condor client code is broken on TeraPort.
> > > Ive tried this on tp-login and tp-osg; I am using +osg-client and
> > @osg in my
> > > .soft. I source $VDT_LOCATION/setup.sh
> > > Zhao, Glen, can you cross-check and see if you are now seeing the
> > same thing?
> > > My suspicion is that the condor client config broke in the last
> > month, through
> > > OSG changes, CI Support work, etc etc.
> > > - Mike
> > > I get this from condor_q:
> > > tp$ condor_q
> > > Error:
> > > Extra Info: You probably saw this error because the condor_schedd is
> > not
> > > running on the machine you are trying to query. If the condor_schedd
> > is not
> > > running, the Condor system will not be able to find an address and
> > port to
> > > connect to and satisfy this request. Please make sure the Condor
> > daemons are
> > > running and try again.
> > > Extra Info: If the condor_schedd is running on the machine you are
> > trying to
> > > query and you still see the error, the most likely cause is that you
> > have
> > > setup a personal Condor, you have not defined SCHEDD_NAME in your
> > > condor_config file, and something is wrong with your
> > SCHEDD_ADDRESS_FILE
> > > setting. You must define either or both of those settings in your
> > config
> > > file, or you must use the -name option to condor_q. Please see the
> > Condor
> > > manual for details on SCHEDD_NAME and SCHEDD_ADDRESS_FILE.
> > > tp$
> > > and this from swift:
> > > tp-grid1$ swift -tc.file tc.data -sites.file sites.condorg.xml
> > cat.swift
> > > Swift svn swift-r2890 cog-r2392
> > > RunID: 20090618-1404-mo0thjj4
> > > Progress:
> > > Progress: Stage in:1
> > > Progress: Submitted:1
> > > Failed to transfer wrapper log from cat-20090618-1404-
> > mo0thjj4/info/h on
> > > firefly
> > > Progress: Failed:1
> > > Execution failed:
> > > Exception in cat:
> > > Arguments: [data.txt]
> > > Host: firefly
> > > Directory: cat-20090618-1404-mo0thjj4/jobs/h/cat-hv5s3gcj
> > > stderr.txt:
> > > stdout.txt:
> > > Caused by:
> > > Cannot submit job: Could not submit job (condor_submit reported an
> > > exit code of 1). no error output
> > > tp-grid1$ ls
> > > Using this sites file:
> > > <config>
> > > <pool handle="firefly" >
> > > <gridftp url="gsiftp://ff-grid.unl.edu" />
> > > <execution provider="condor" />
> > > <profile namespace="globus" key="jobType">grid</profile>
> > > <profile namespace="globus" key="gridResource">gt2
> > > ff-grid.unl.edu/jobmanager-pbs</profile>
> > > <workdirectory
> > >/panfs/panasas/CMS/data/oops/wilde/swiftwork</workdirectory>
> > > </pool>
> > > </config>
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090619/c247bbb7/attachment.html>
