[Swift-devel] Overview of coaster block-allocation-version	issues
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jun 19 08:31:32 CDT 2009
On 6/19/09 8:23 AM, Mihael Hategan wrote:
> On Fri, 2009-06-19 at 07:47 -0500, Michael Wilde wrote:
>> More thoughts on this:
>> (2) is a showstopper on Ranger (and possible elsewhere) and hence a much
>> more important issue than (1).
>> It seems like this problem merits a 2-pronged attack:
>> a) reduce the overhead. Is it logging, or intrinsic to the protocol?
>>    -- is it obvious from the log whats causing the high overhead?
>>    -- its it a situation where the overhead is incurred even when
>>       jobs are not running, just queued?
> Some profiling needs to be done.
Zhao or Allan, can you reproduce the problem on TeraPort or UC Teragrid,
using a simple script and dummy app so that Mihael can readily reproduce?
Mihael, do you want them to run with profiling and post results?
- Mike
>> b) see if the service can be moved to a worker node
>> Mike
>> On 6/18/09 4:59 PM, Michael Wilde wrote:
>>> Zhao and Allan have been testing the new coaster block-allocation
>>> version on Ranger.
>>> They have reported some issues, and need to work with Mihael to better
>>> characterize the errors, and try to reproduce them in a way that Mihael
>>> can also do.
>>>  From working with them, I see two more issues that should be discussed
>>> and resolved, which I think they have not yet mentioned on the list.
>>> Zhao will discuss at least one of these, but is swamped getting a
>>> science run completed for the SEE project.
>>> The issues:
>>> 1) Its hard to configure the time dimensions of the allocator, and to
>>> make it work well with Swift retry parameters.  The properties listed in
>>> the table in the User Guide coaster section need more explanation and
>>> examples. I think Zhao in his latest run got these working OK for the
>>> "ampl" SEE model he's running (2000 jobs, 2 hours each).  I'll work with
>>> him on this, but help from others is welcome.
>>> 2) Allan and Zhao got kicked off of Ranger because the Coaster service
>>> was consuming too much time on the head node, which is also "login3". We
>>> were impacting other users, and got a "cease and desist" order from the
>>> Ranger sysadmin.  They have at least one anecdotal "top" snapshot from
>>> the host that indicates the service was indeed using a lot of time (on
>>> his 2000 job x 2 hour script).  At the same time, Zhao sees a huge
>>> coaster (service?) log. Maybe related?
>>> Allan and Zhao, please keep updates flowing to swift-devel with the list
>>> and status of coaster issues (ideally bugzilla'ed when appropriate), and
>>> work with Mihael to capture the logs and test cases he needs to see for
>>> each problem.  Can you both work together to make a list, and with
>>> Mihael to decide which items need to be tracked as bugs?
>>> Thanks,
>>> Mike
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
