[Swift-devel] Overview of coaster block-allocation-version issues
Michael Wilde
wilde at mcs.anl.gov
Fri Jun 19 07:47:47 CDT 2009
More thoughts on this:
(2) is a showstopper on Ranger (and possible elsewhere) and hence a much
more important issue than (1).
It seems like this problem merits a 2-pronged attack:
a) reduce the overhead. Is it logging, or intrinsic to the protocol?
-- is it obvious from the log whats causing the high overhead?
-- its it a situation where the overhead is incurred even when
jobs are not running, just queued?
b) see if the service can be moved to a worker node
Mike
On 6/18/09 4:59 PM, Michael Wilde wrote:
> Zhao and Allan have been testing the new coaster block-allocation
> version on Ranger.
> They have reported some issues, and need to work with Mihael to better
> characterize the errors, and try to reproduce them in a way that Mihael
> can also do.
> From working with them, I see two more issues that should be discussed
> and resolved, which I think they have not yet mentioned on the list.
> Zhao will discuss at least one of these, but is swamped getting a
> science run completed for the SEE project.
> The issues:
> 1) Its hard to configure the time dimensions of the allocator, and to
> make it work well with Swift retry parameters. The properties listed in
> the table in the User Guide coaster section need more explanation and
> examples. I think Zhao in his latest run got these working OK for the
> "ampl" SEE model he's running (2000 jobs, 2 hours each). I'll work with
> him on this, but help from others is welcome.
> 2) Allan and Zhao got kicked off of Ranger because the Coaster service
> was consuming too much time on the head node, which is also "login3". We
> were impacting other users, and got a "cease and desist" order from the
> Ranger sysadmin. They have at least one anecdotal "top" snapshot from
> the host that indicates the service was indeed using a lot of time (on
> his 2000 job x 2 hour script). At the same time, Zhao sees a huge
> coaster (service?) log. Maybe related?
> Allan and Zhao, please keep updates flowing to swift-devel with the list
> and status of coaster issues (ideally bugzilla'ed when appropriate), and
> work with Mihael to capture the logs and test cases he needs to see for
> each problem. Can you both work together to make a list, and with
> Mihael to decide which items need to be tracked as bugs?
> Thanks,
> Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
