[Swift-devel] Cant run condor-g on TeraPort
Zhao Zhang
zhaozhang at uchicago.edu
Thu Jun 18 14:32:19 CDT 2009
Hi, Mike
Michael Wilde wrote:
> As far as I can tell, the condor client code is broken on TeraPort.
> Ive tried this on tp-login and tp-osg; I am using +osg-client and @osg
> in my .soft. I source $VDT_LOCATION/setup.sh
> Zhao, Glen, can you cross-check and see if you are now seeing the same
> thing?
> My suspicion is that the condor client config broke in the last month,
> through OSG changes, CI Support work, etc etc.
> - Mike
> I get this from condor_q:
condor_q is working for me
[zzhang at tp-grid1 sites]$ condor_q
-- Submitter: tp-grid1.ci.uchicago.edu : <128.135.125.118:43109> :
ID OWNER SUBMITTED RUN_TIME ST PRI SIZE
CMD
101.0 zzhang 4/28 16:15 0+00:02:06 X 0 1.0 bash
/nfs/home/osg
137.0 zzhang 4/29 12:25 0+00:00:00 X 0 1.0 bash
/nfs/osg-data
138.0 zzhang 4/29 13:02 0+00:00:00 X 0 1.0 bash
/scratch/ufhp
139.0 zzhang 4/29 16:15 0+00:00:00 X 0 1.0 bash
/opt/osg/data
140.0 zzhang 5/5 14:12 0+00:00:43 X 0 1.0 bash
/nfs/osg-data
157.0 zzhang 5/5 14:49 0+00:00:00 X 0 1.0 bash
/atlas/data08
158.0 zzhang 5/5 14:59 0+00:00:00 X 0 1.0 bash
/raid2/osg-da
159.0 zzhang 5/5 15:03 0+00:00:00 X 0 1.0 bash
/raid2/osg-da
The source file in my .bashrc is "source /opt/osg/setup.sh" not
"/opt/osg-ce-1.0.0-r2/setup.sh".
[zzhang at tp-grid1 sites]$ echo $VDT_LOCATION
zhao
> tp$ condor_q
> Error:
> Extra Info: You probably saw this error because the condor_schedd is not
> running on the machine you are trying to query. If the condor_schedd
> is not
> running, the Condor system will not be able to find an address and
> port to
> connect to and satisfy this request. Please make sure the Condor
> daemons are
> running and try again.
> Extra Info: If the condor_schedd is running on the machine you are
> trying to
> query and you still see the error, the most likely cause is that you have
> setup a personal Condor, you have not defined SCHEDD_NAME in your
> condor_config file, and something is wrong with your SCHEDD_ADDRESS_FILE
> setting. You must define either or both of those settings in your config
> file, or you must use the -name option to condor_q. Please see the Condor
> manual for details on SCHEDD_NAME and SCHEDD_ADDRESS_FILE.
> tp$
> and this from swift:
> tp-grid1$ swift -tc.file tc.data -sites.file sites.condorg.xml cat.swift
> Swift svn swift-r2890 cog-r2392
> RunID: 20090618-1404-mo0thjj4
> Progress:
> Progress: Stage in:1
> Progress: Submitted:1
> Failed to transfer wrapper log from cat-20090618-1404-mo0thjj4/info/h
> on firefly
> Progress: Failed:1
> Execution failed:
> Exception in cat:
> Arguments: [data.txt]
> Host: firefly
> Directory: cat-20090618-1404-mo0thjj4/jobs/h/cat-hv5s3gcj
> stderr.txt:
> stdout.txt:
> Caused by:
> Cannot submit job: Could not submit job (condor_submit reported an
> exit code of 1). no error output
> tp-grid1$ ls
> Using this sites file:
> <config>
> <pool handle="firefly" >
> <gridftp url="gsiftp://ff-grid.unl.edu" />
> <execution provider="condor" />
> <profile namespace="globus" key="jobType">grid</profile>
> <profile namespace="globus" key="gridResource">gt2
> ff-grid.unl.edu/jobmanager-pbs</profile>
> <workdirectory
> >/panfs/panasas/CMS/data/oops/wilde/swiftwork</workdirectory>
> </pool>
> </config>
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
