[Swift-devel] Cant run condor-g on TeraPort
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jun 18 14:22:10 CDT 2009
As far as I can tell, the condor client code is broken on TeraPort.
Ive tried this on tp-login and tp-osg; I am using +osg-client and @osg
in my .soft. I source $VDT_LOCATION/setup.sh
Zhao, Glen, can you cross-check and see if you are now seeing the same
thing?
My suspicion is that the condor client config broke in the last month,
through OSG changes, CI Support work, etc etc.
- Mike
I get this from condor_q:
tp$ condor_q
Error:
Extra Info: You probably saw this error because the condor_schedd is not
running on the machine you are trying to query. If the condor_schedd is not
running, the Condor system will not be able to find an address and port to
connect to and satisfy this request. Please make sure the Condor daemons
are
running and try again.
Extra Info: If the condor_schedd is running on the machine you are
trying to
query and you still see the error, the most likely cause is that you have
setup a personal Condor, you have not defined SCHEDD_NAME in your
condor_config file, and something is wrong with your SCHEDD_ADDRESS_FILE
setting. You must define either or both of those settings in your config
file, or you must use the -name option to condor_q. Please see the Condor
manual for details on SCHEDD_NAME and SCHEDD_ADDRESS_FILE.
tp$
and this from swift:
tp-grid1$ swift -tc.file tc.data -sites.file sites.condorg.xml cat.swift
Swift svn swift-r2890 cog-r2392
RunID: 20090618-1404-mo0thjj4
Progress:
Progress:  Stage in:1
Progress:  Submitted:1
Failed to transfer wrapper log from cat-20090618-1404-mo0thjj4/info/h on
firefly
Progress:  Failed:1
Execution failed:
	Exception in cat:
Arguments: [data.txt]
Host: firefly
Directory: cat-20090618-1404-mo0thjj4/jobs/h/cat-hv5s3gcj
stderr.txt:
stdout.txt:
Caused by:
	Cannot submit job: Could not submit job (condor_submit reported an exit
code of 1). no error output
tp-grid1$ ls
Using this sites file:
<config>
  <pool handle="firefly" >
   <gridftp  url="gsiftp://ff-grid.unl.edu" />
   <execution  provider="condor" />
   <profile namespace="globus" key="jobType">grid</profile>
   <profile namespace="globus" key="gridResource">gt2
ff-grid.unl.edu/jobmanager-pbs</profile>
   <workdirectory
 >/panfs/panasas/CMS/data/oops/wilde/swiftwork</workdirectory>
  </pool>
</config>
