[Swift-devel] passing very long lists of files to applications
    Ben Clifford
    benc at hawaga.org.uk
    Tue Jun 16 05:10:59 CDT 2009
a related idea to this when you are using some component program that is
summarising data and is associative (and maybe other properties) in its
work is that the associativity could be indicated to Swift, and Swift
could then make use of that to generate an arbitrary number of app calls.
For example, the numerical operations max or sum fit this, but mean
does not.
max (100,8,1,1,33,8,7,423,46,2,222) = max(   max(100,8,1,1), max(33,8),
max(7,423,46), max(2,222) )
so its possible to evaluate the max without any individual invocation
having more than 4 parameters.
This fits in quite nicely with ideas of having Swift stuff be expressed
more functionally, and have Swift able to make its own decisions about
exactly how things are run.
I don't think this is going to be something that goes in the language
soon, but if anyone happens to pursue the functional direction further,
this is a case that should be kept in mind.
