[Swift-devel] Re: block coasters not registering on proper queue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 12 19:20:17 CDT 2009
There's a chance an intermittent coaster bug still exists on this issue.
So it would be useful to test the same configuration some more.
On Fri, 2009-06-12 at 15:33 -0500, Allan Espinosa wrote:
> I did a rebuild (ant redist) today and it looks like everything is
> working fine.  It looks like some files during my previous build were
> not updated properly.  I was using rsync to copy files from swift-svn
> to another directory.  i guess that was a bad idea.
> ./runtest.sh
> Swift svn swift-r2949 cog-r2406
> RunID: coasterrun
> Progress:  uninitialized:1
> Progress:  Submitted:1
> Progress:  Active:1
> Final status:  Finished successfully:1
> Cleaning up...
> Shutting down service at https://128.135.125.117:43627
> Got channel MetaChannel: 1910518671 -> GSSSChannel-null(1)
> - Done
> qstat:
> 1095930.tp-mgt            null             aespinosa              0 R fast
> -Allan
> 2009/6/8 Allan Espinosa <aespinosa at cs.uchicago.edu>:
> > Is there a default maxwalltime being submitted to the LRM if nothing
> > is specified?  I made in this configuration to use the "fast" ueue in
> > sites.xml but i keep getting placed inside the "exteneded" queue.
> > sites.xml
> > <config>
> >  <pool handle="teraport" >
> >    <gridftp url="gsiftp://tp-osg.ci.uchicago.edu" />
> >    <execution provider="coaster" url="tp-osg.ci.uchicago.edu"
> > jobmanager="gt2:gt2:pbs" />
> >    <profile namespace="globus" key="queue">fast</profile>
> >    <workdirectory>/home/aespinosa/work</workdirectory>
> >    <profile namespace="karajan" key="initialScore">50</profile>
> >    <profile namespace="karajan" key="jobThrottle">10</profile>
> >    <profile namespace="globus" key="slots">20</profile>
> >  </pool>
> > </config>
> > gram log snippet:
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: New Perl JobManager created.
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Using jm supplied job dir:
> > /home/aespinosa/.globus/job/tp-grid1.ci.uchicago.edu/18222.1244495960
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Entering pbs submit
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: NFS sync for /usr/bin/perl failed
> > (may be harmless): Operation not permitted
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Sent NFS sync for /usr/bin/perl
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: NFS sync for /dev/null failed (may
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Sent NFS sync for /dev/null
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Determining job max time cpu from
> > job description
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT:    using queue default
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Determining job max wall time
> > limit from job description
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT:    using maxwalltime of 60
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Building job script
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Transforming argument
> > "/home/aespinosa/.globus/coasters/cscript6820117662705473060.pl"
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Transformed to
> > "http://128.135.125.118:56015"
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Transforming argument "0608-190415-000000"
> > Mon Jun  8 16:19:21 2009 JM_SCRIPT: Transformed to "0608-190415-000000"
> > $grep fast gram*.log:
> > gram_job_mgr_18021.log:6/8 16:19:15 JMI: poll_fast: returning -1 =
> > GLOBUS_FAILURE (try Perl scripts)
> > gram_job_mgr_18021.log:6/8 16:19:25 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18021.log:6/8 16:19:36 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:19:22 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:19:32 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:19:43 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:19:53 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:20:03 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:20:14 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:20:24 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:20:34 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:20:45 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:20:55 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:21:05 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:21:16 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:21:26 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:21:36 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:21:47 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:21:57 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:22:08 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:22:18 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:22:28 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:22:39 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:22:49 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:23:00 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:23:10 JMI: poll_fast: returning -1 =
> > gram_job_mgr_18222.log:6/8 16:23:20 JMI: poll_fast: returning -1 =
> > Swift version: Swift svn swift-r2949 cog-r2406
> > -Allan
