[Swift-devel] swift in softenv at CI
Ben Clifford
benc at hawaga.org.uk
Fri Jun 12 13:21:08 CDT 2009
For people using CI maintained login machines, Swift is now available in
softenv. To get Swift 0.9 in the same way that you get other CI software,
add the line:
@swift
to the start of your ~/.soft file.
The full commentary from CI support is:
> There's a @swift macro which is recommended to use before the @default
> macro and that will pull in the Sun Java for that OS and swift. And
> there's also a +swift if someone wants to try out a different Java.
