[Swift-devel] Re: coaster error on ranger
Mihael Hategan
hategan at mcs.anl.gov
Thu Jun 11 13:24:58 CDT 2009
On Thu, 2009-06-11 at 13:13 -0500, Zhao Zhang wrote:
> Hi, Mihael
> Actually, I have no idea how long would these jobs run. Some of them
> just took ~10 minutes, and some of them went far more than this.
> What if I set the wall to 120 minutes, what will happen when the wall
> time is up but the job doesn't finish?
You'll probably send another message to the mailing list saying that
things don't work properly. And I'll ask you again to gather all logs.
Then I'll tell you the same thing, which is that you should set a proper
maxwalltime for the job.
> <profile namespace="globus" key="maxtime">120</profile>
Read the swift documentation, in particular
http://www.ci.uchicago.edu/swift/guides/userguide.php#profile.globus
(how to specify the maxwalltime and what it means, and the meaning of
"maxtime" which has nothing to do with your job's maximum walltime).
